March 09, 2026, 09:16:13 21:16
Author Topic: how can i do  (Read 4911 times)
eloman
« on: September 13, 2007, 09:45:10 21:45 »
i want to make a robot, it will has got a camera and it will see the any parts and mesure the parts. how can i mesure with cam. sorry for my poor english.
nacho1
-Given: 24
« Reply #1 on: September 13, 2007, 10:13:24 22:13 »
I've heard of som c Library, its free code. this library its used in ternium/siderar (ARG) to measure the steel in the process. but i dont know where it can be downloaded.
i hope this helps
bye
FaithNoMore
Translator
-Given: 16
-Receive: 91
« Reply #2 on: September 14, 2007, 03:16:25 03:16 »
The CMUcam1 Vision Sensor
CMUcam is a new low-cost, low-power sensor for mobile robots.
You can use CMUcam vision system to do many different kinds of on-board, real-time vision processing.
Because CMUcam uses a serial port, it can be directly interfaced to other low-power processors such as PIC chips.
At 17 frames per second, CMUcam can do the following:
    * track the position and size of a colorful or bright object
    * measure the RGB or YUV statistics of an image region
    * automatically acquire and track the first object it sees
    * physically track using a directly connected servo
    * dump a complete image over the serial port
    * dump a bitmap showing the shape of the tracked object
Info:   http://www.cs.cmu.edu/~cmucam/home.html
