April 13, 2026, 11:51:36 11:51
Author Topic: DeskProto 32/64 bit (2510)  (Read 34844 times)
gmua
-Receive: 88
« on: April 10, 2013, 05:57:45 17:57 »
DeskProto v6.0 32-bit (2510) offers 3D CNC machining for non-machinists.
DeskProto is a 3D CAM program (CAM = Computer Aided Manufacturing).
It can import STL files from any 3D CAD program, calculate CNC toolpaths and then write NC program files for any CNC milling machine: 3-axis, 4-axis and 5-axis.
DeskProto is aimed at designers for Rapid Prototyping, at jewelers for wax models, artists for sculptures, medics for prostheses, moldmakers, woodworkers, teachers, students, hobbyists, etc..
UPDATE: Reply #6 has a new download link with new medicine.
« Last Edit: September 27, 2013, 09:55:53 09:55 by pickit2 » Logged
gabi68
« Reply #1 on: April 10, 2013, 09:05:39 21:05 »
I think this is a 64 bit version with a 32 bit medicine. Someone can confirm this? I try to install it and failed. Any help...?
gmua
-Receive: 88
« Reply #2 on: April 11, 2013, 12:11:16 00:11 »
I'm sorry gabi68, the installer contains both versions, which one is installed, depends on your Windows version, I could not install the 32 bit version on my 64 bit Windows 7, so I had to try it in my 32 bit machine, the medicine works fine with 32 bit but not with 64, sorry again.
#tester
-Receive: 15
« Reply #3 on: April 12, 2013, 10:17:12 22:17 »
gabi68 How about installing it as full version, which will count down uses, unless you run a clockstopper or runasdate program, search will show dl links.
gabi68
« Reply #4 on: April 14, 2013, 09:20:11 09:20 »
I'm sorry gabi68, the installer contains both versions, which one is installed, depends on your Windows version, I could not install the 32 bit version on my 64 bit Windows 7, so I had to try it in my 32 bit machine, the medicine works fine with 32 bit but not with 64[/color], sorry again.
Do you have a 64 bit medicine?
EDIT: so busy leeching can't read.
« Last Edit: December 16, 2014, 12:47:39 12:47 by pickit2 » Logged
gmua
-Receive: 88
« Reply #5 on: September 12, 2013, 02:21:45 02:21 »
No, but I'm still looking for it (My main computer has Windows 7 64 bits installed), if I find it, I will post it.
Posted on: April 15, 2013, 09:58:59 21:58 - Automerged
DeskProto v6.0 32-bit (3571) offers 3D CNC machining for non-machinists.
Revision 3571 includes:
- In the Basic 3D wizard the supports were cut loose (the wizard did not set the Borders).
- Toolpath calculations could crash for: Conic_cutter and Angle_with_X and Always_stay_low on.
- A new build for only two fixes, because the supports bug was a very serious one, confusing new users.
pilotensitz
-Given: 21
-Receive: 32
« Reply #6 on: September 20, 2013, 06:13:58 18:13 »
Hi!
It works for me with the following workaround:
1. Install deskproto (link.txt from last posting here)
2. Install it also in a Vm-Ware with Win XP Mode (mine is XP Mode with SP3) and use the crack. It works here now
3. Copy/replace the whole content of the folder with your folder on your main x64 machine
At the first start, it crashed the programm but after secont start it worked fine till now.
I dont know, if step 1 is necessary. Please report here, if you had success!
Greetings,
p i l o t e n s i t z
« Last Edit: September 20, 2013, 06:49:34 18:49 by pilotensitz » Logged
gmua
-Receive: 88
« Reply #7 on: September 25, 2013, 05:04:54 17:04 »
Great tip pilotensitz, let's wait to hear how it went for gabi68.
sale030
« Reply #8 on: November 10, 2013, 09:44:31 09:44 »
Hi everybody.
Download link no more exist. Can someone upload new one, please???
Greetings
sgoum
-Given: 94
-Receive: 68
« Reply #9 on: November 10, 2013, 04:33:02 16:33 »
Here it is
vegas
« Reply #10 on: December 16, 2013, 07:20:06 07:20 »
 Cry  hello to all. Unfortunately, my version of w7 is home premium and I can not install the VM. there is another way to make the program work?
mare69
-Given: 50
-Receive: 85
« Reply #11 on: October 20, 2014, 10:53:39 10:53 »
Can someone upload new download link, please?
Tnx!
73
snowman
-Given: 187
-Receive: 53
« Reply #12 on: October 20, 2014, 02:12:19 14:12 »
mega.co link is working by gmua
pilotensitz
-Given: 21
-Receive: 32
« Reply #13 on: February 01, 2015, 03:03:45 15:03 »
DeskProto v6.1 english, Entry edition
see attached file
greetings
« Reply #14 on: April 02, 2015, 07:15:29 07:15 »
I am trying rotary axis machining, seems Deskproto is good for this.
Install the DeskProto v6.0 32-bit (3571) both on Win7 32 and 64 (with pilotensitz method), everything fine until saving the generated toolpath - an error like picture below. Anyone experience the same?
« Reply #15 on: April 10, 2015, 05:32:09 17:32 »
The error above doesn't happen with 2510 version.
Then i found serial number on Russian website which work on the latest English trial version (4819) making it a working multi axis edition Tongue.
But, worry this sn will be blacklisted soon  Sad.
alm555
-Receive: 117
« Reply #16 on: January 24, 2016, 04:32:00 16:32 »
DeskProto v6.1 (5531), Entry edition
ELCouz
-Given: 8
« Reply #17 on: February 08, 2016, 11:56:30 23:56 »
You can run any recent trial version in a VM image.
This is what I do.
Restore the snapshot when 30 days are expired.
Be sure to have the following lines in the vmx file (vmware)
Otherwise the armadillo software protection included in the software is gonna detect VMware running and invalidate the trial period
monitor_control.restrict_backdoor = "TRUE"
hypervisor.cpuid.v0 = "FALSE"
alm555
-Receive: 117
« Reply #18 on: March 15, 2016, 02:38:31 14:38 »
DeskProto 6.1 Multi-Axis Edition
Grantorax
« Reply #19 on: April 03, 2016, 03:21:18 03:21 »
Last Link Faild....
