March 12, 2026, 11:03:54 23:03
Author Topic: looking for smd connector  (Read 6386 times)
leptro
-Receive: 26
« on: April 04, 2013, 08:32:58 20:32 »
hello to all,
i am looking for a place to buy  this kind of smd connector , any help will be apreciate.
http://jumperone.com/images/2011/10/thermostat-project-part2/003.jpg
thank you for your help.
optikon
-Given: 1138
-Receive: 2008
« Reply #1 on: April 05, 2013, 12:04:17 00:04 »
hello to all,
This connector is very common.
Try digikey, mouser, future, newark, Jameco....
A little searching, you will find it in stock.
Faros
-Given: 141
-Receive: 178
« Reply #2 on: April 05, 2013, 12:37:19 00:37 »
you mean any place worldwide or you have a particular country in mind ?
@Farnell
Datasheet:
http://www.farnell.com/datasheets/318453.pdf
Manufacturer: TE CONNECTIVITY / AMP
Order Code: 9689621
Farnell export product page:
http://export.farnell.com/te-connectivity-amp/1-1241050-0/header-smt-2x10way/dp/9689621
« Last Edit: April 05, 2013, 12:39:30 00:39 by Faros » Logged
-Given: 499
« Reply #3 on: April 05, 2013, 01:25:33 01:25 »
I think the description would be SMD DIL 0.1 unprotected header
sarah90
« Reply #4 on: April 05, 2013, 07:08:30 19:08 »
Ebay: http://www.ebay.com/itm/4-pcs-double-row-straight-pin-header-SMD-type-/251255469220
leptro
-Receive: 26
« Reply #5 on: April 06, 2013, 08:17:30 08:17 »
thank you for all your answers;
yes this is a common connector but the distributor classification are not optimize.
May be my translation from french to english was not good enough.
but all my search for " smd or smt pin header" gave me bad result.
best regards.
Old_but_Alive
-Given: 833
-Receive: 122
« Reply #6 on: April 06, 2013, 09:10:53 09:10 »
its a Samtec connector, I bought many about 5 years ago.
so get a Samtec  catalogue, work out the part number, then go buy from a distributor in your country
http://www.samtec.com/Documents/WebFiles/Current_Literature/SAMTEC_F-213_CATALOG_lores.pdf
page 212, the TSM series is what you want (assuming 0.1" pitch)
I have some 16 pin versions, 2.54mm pitch, you can cut them down of course to make a 16+4=20
If its just 2 or 3, i will send you some if you send me a pm with your address.
Mike
« Last Edit: April 06, 2013, 09:37:54 09:37 by Old_but_Alive » Logged
pushycat
-Given: 243
-Receive: 1448
« Reply #7 on: April 06, 2013, 09:42:37 09:42 »
Looking at the Picture i guess it is a common connector with 2.54mm pin spacing. If i was in your place i would have happily used the through hole one by carefully bending the pins to 90 degrees. Even if you accidently break one pin, you can easily slide the new one by pulling the damaged one out using a plier.
Pushy
leptro
-Receive: 26
« Reply #8 on: April 07, 2013, 01:09:39 13:09 »
@ old_but_alive.  thank you for your sharing intention, i think i will order some 2x40 for my stock. i will contact you if i failed to find a distributor  that want to deliver to my country.
@ pusycat : i tried this first but the result is not good enough for me.
i actuallly want to use them to redesign a double sided 7 segment display board where the connector was mount at the buttom side.
Old_but_Alive
-Given: 833
-Receive: 122
« Reply #9 on: April 07, 2013, 02:40:01 14:40 »
farnell have them, and I am sure you can get them in France
http://uk.farnell.com/jsp/search/browse.jsp?N=2031+204643+110149834+110201457&Ntk=gensearch&Ntt=samtec+tsm&Ntx=mode+matchallpartial&No=0&getResults=true&appliedparametrics=true&locale=en_UK&divisionLocale=en_UK&catalogId=&skipManufacturer=false&skipParametricAttributeId=&prevNValues=2031+204643+110194755+110149834&mm=1002208||,1002541||,&filtersHidden=false&appliedHidden=false&autoApply=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D2031%2B204643%26Ntk%3Dgensearch%26Ntt%3Dsamtec%2Btsm%26Ntx%3Dmode%2Bmatchallpartial%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_UK%26divisionLocale%3Den_UK%26catalogId%3D%26skipManufacturer%3Dfalse%26skipParametricAttributeId%3D%26prevNValues%3D2031%2B204643
copy and paste ALL of the link
this one looks OK
http://uk.farnell.com/samtec/tsm-110-01-t-dv/header-2-54mm-smt-20way/dp/2056037
 farnell code 2056037
they have several different types, so make sure you compare and choose the correct one.
« Reply #10 on: April 13, 2013, 04:43:38 16:43 »
It looks like a .05" spacing connector to me, not a 0.1"
leptro
-Receive: 26
« Reply #11 on: April 14, 2013, 10:10:53 10:10 »
this is really a 0.1'' connector. But this is not a problem for me because i design my own board with eagle. so i have the choice of the connector i want to use.
« Reply #12 on: April 14, 2013, 02:43:36 14:43 »
Okay,
Well Tyco, 3M and Samtec should all have readily available solutions from most major distributors.  Thru hole version will be a little easier to get but the SMD version you show shouldn't be that hard either.
Here is a starting point:
http://www.digikey.com/scripts/dksearch/dksus.dll?FV=fff40016%2Cfff802f3%2C700785%2C70078c%2C1600022%2C1680002&k=connector+header+0.1%22&vendor=0&mnonly=0&newproducts=0&ptm=0&fid=0&quantity=0&PV69=3
you can cross ref the manf part numbers with a distributor in your country.
galaxy
« Reply #13 on: June 11, 2013, 07:51:28 19:51 »
you know you can order free samples from MOLEX
they ship it for free too
leptro
-Receive: 26
« Reply #14 on: June 13, 2013, 07:18:28 07:18 »
i have finally make an order from a china ebay seller.
It was the best choise because i was not in a hurry (more than a month to wait)and it was the best price.
No problem with the quality.
regards.
