April 29, 2026, 06:06:05 06:06
Author Topic: Feedback and control (Any control experts?)  (Read 5108 times)
PM3295
-Given: 365
-Receive: 157
« on: March 27, 2013, 04:12:03 16:12 »
Someone asked me this question:
When we have a negative-feedback system:
We know; The system will be stable as long as the overall gain stays below 0dB (with some margin)when we reach -180° phase shift point.
a) What happens if the phase shift goes to +180°, for some reason, and the gain is more than 0dB?
b) What happens if the phase goes to more than +180° (say +200°, 250°) with more than 0dB gain?
I looked through my old books but can't find any example of a negative-feedback system having large positive phase shifts.
All the examples only deal with stability issues approaching the -180° point.
I hope some control expert can clarify this.
optikon
-Given: 1139
-Receive: 2008
« Reply #1 on: March 27, 2013, 05:09:18 17:09 »
You just have to consider the whole phase shift around the loop of the feedback system. It answers all your questions about stability.
a) If the overall loop achieves a total of 360 degrees or more with > 0 dB gain, you will have instability
b) See "a"
PM3295
-Given: 365
-Receive: 157
« Reply #2 on: March 27, 2013, 08:50:29 20:50 »
So, basically we only need to look at either +180° or -180° and if the gain is > 0 it will be unstable?
optikon
-Given: 1139
-Receive: 2008
« Reply #3 on: March 27, 2013, 09:10:53 21:10 »
I think the 180 phase requirement you are thinking about might come from the fact that your forward path has already contributed 180 degrees phase shift. Is this correct? I think that is the standard control system model. But the actual condition for instability is the loop (forward and feedback) must achieve 360 or more phase with a loop gain > 0dB.
The previous statement is general and covers all feedback cases. What is the model you are thinking about?
PM3295
-Given: 365
-Receive: 157
« Reply #4 on: March 27, 2013, 10:09:34 22:09 »
That is the case. I have no specific model in mind.
nordiceng
« Reply #5 on: April 20, 2013, 05:03:07 05:03 »
  When the phase shift goes to 180°, the control system is most likely will be unstable
Old_but_Alive
-Given: 840
-Receive: 122
« Reply #6 on: April 20, 2013, 10:47:45 10:47 »
its not just a go-no  go situation.
There must be a margin away from the raw gain <1 at 180
there is a need to be some way away from that situation.
have a look at
http://www.ridleyengineering.com/loop-stability-requirements.html
this next one is a bit heavy, but try it
http://www.eeng.nuim.ie/~rfarrell/EE301/notes/EE309_notes_18.pdf
bigtoy
-Given: 365
-Receive: 297
« Reply #7 on: April 20, 2013, 06:43:38 18:43 »
Consider a simple example, with a constant DC input. With 180 degree phase shift and gain > 1, the output will increase in value each time we "go around the loop". So the output will increase without bound.
