April 29, 2026, 07:13:51 07:13
Author Topic: can't success simulate eeprom 24c32 in proteus , help  (Read 5977 times)
xmobix
« on: September 06, 2007, 02:32:44 02:32 »
hi
please can someone upload here a simple pcbasic pro program to make eeprom 24c32 working oerfect with pic16f876
in proteus v7.1
thanks in advance.
samir
-Given: 27
-Receive: 21
« Reply #1 on: September 06, 2007, 06:50:35 06:50 »
hi
in proteus v7.1
thanks in advance.
this might be some bug in demo or cracked version
i have faced same problem while using Ethernet demo and tru to update web page on serial eeprom and i was failed.in my case the content on original  data are not changing.
Ret12_12
-Given: 104
-Receive: 32
« Reply #2 on: September 09, 2007, 12:10:23 12:10 »
That i believe too i have test and the 24LC16 - 24LC 256 but no success it works ok in very old version (No more protection there)
xmobix
« Reply #3 on: September 14, 2007, 02:02:58 02:02 »
hi friends
I have used proteus v7.1 sp4 with licence key to simulate I2C eeprom 24cxx , but no success , also I have problem with portA especially porta.4 and porta.5 when use pic16f876A whats the problem
thanks.
Ret12_12
-Given: 104
-Receive: 32
« Reply #4 on: September 14, 2007, 02:46:10 14:46 »
for the porta.4 you must put a resistor 10k to the Vcc 5v but for the rest maybe it is license problem  Undecided
xmobix
« Reply #5 on: September 14, 2007, 03:13:48 15:13 »
ok i'll try
thanks
sofy2
« Reply #6 on: September 18, 2007, 03:16:11 15:16 »
when you use the eeprom do not miss  delay >=5ms  after  writing in the eeprom
zeus
-Given: 46
-Receive: 35
« Reply #7 on: September 18, 2007, 10:32:18 22:32 »
 Huh
Reading from I2C EEPROM not succesccful both HW an SW programming method !
xmobix
« Reply #8 on: September 19, 2007, 12:32:34 00:32 »
hi
test delay >=5m and test from 1m to 10m and not working
may be bug in software
Ret12_12
-Given: 104
-Receive: 32
« Reply #9 on: September 19, 2007, 05:49:15 17:49 »
i remember 6.5 sp2 or lower version it was working success, is anyone has keep the old version so to confirm that ?
fagari
-Receive: 41
« Reply #10 on: September 22, 2007, 07:02:27 07:02 »
You can Download my 24C32 Eeprom Project here.
(Sorce code and Proteus file)
http://www.sonsivri.com/forum/index.php?topic=5501.0
 Grin
elreypic
« Reply #11 on: September 26, 2007, 05:44:08 17:44 »
Hi all
There is a little trick to simulate the I2C devices on proteus. When you put the pull-up resistors. Click on left button on Edit properties, select Digital instead of Analog. Click on OK button. That's it.
I hope this be useful for everybody.
Elreypic.
xmobix
« Reply #12 on: September 28, 2007, 01:19:59 01:19 »
hi
change pull-up resistor from Analog to digital not solve the problem for me
values read from eeprom 24c32 change but not the real values that I program on it
thanks for your opinion.
Ret12_12
-Given: 104
-Receive: 32
« Reply #13 on: September 30, 2007, 11:52:09 11:52 »
The tip from xmobix it's working well Wink  Great tip Smiley
xmobix
« Reply #14 on: September 30, 2007, 11:11:07 23:11 »
sorry for elreypic
your solution work great
thanks friend ,I was wrong
