April 21, 2026, 03:29:27 15:29
Author Topic: Microcontroller Based Schematics  (Read 39318 times)
egealtay
-Receive: 78
« on: September 02, 2007, 10:53:24 22:53 »
http://www.hobbyprojects.com/quick_circuits_reference/microcontroller_based_schematics.html
10 tricks for interfacing to the PIC16C508
101 AT Keyboard to ASCII Decoder using 68HC705J1A MCU
128x64 LCD Driver for AT90S2313 (ZIP file)
27c801 EPROM Programmer Project
2-wire LCD interface using PIC16CF84
40+ MHz 5-digit frequency counter with an AVR 2313
4-Channel Timer using Atmel 89C4051 and MAX7219 display driver
50 MHz frequency counter, voltage meter & SWR/PWR indicator
68HC11 based RDS decoder
68HC11 stepper motor control
8051 Development System Circuit Board 1
8051 Development System Circuit Board 2
8051 Development System Circuit Board 3
8051 SBC (single board computer)
8088 maximum mode SBC
80C31 stepper motor controller
90S2313 AVR Robot Board
A Scenix (and PIC) Programmer
Acceleration monitor using ADXL202 and AVR
AFSK 1200 Modem based on PIC16C620
Analog datalogger based on T89C51RD2
Analog to digital conversion notes
AT89C2051 Digital thermometer and clock
AT89C2051 line-follower robot
AT89C2051 Night light saver
AT89C2051 real-time controller
AT89C2051 serial COMs to LED driver
AT89C2051/4051 Driving dot LED
AT89C2051/4051 Easy-Downloader
AT89C2051/4051connecting dumb terminal
AT89C2051/4051scanning 7-segment display and keypad
AT89C2051/4051stepper motor interface
AT89C51/52/55 Easy-Downloader
AT90S8515 experimenter board
Atmel 8051 Flash Based-Microcontroller Programmer
Atmel 89C Series Flash Microcontroller Programmer
Atmel 89C2051 In-Circuit Programmer Schematic
Atmel 89C2051 prototype board
Atmel AVR and 8051 series ISP programmer
Automatic door opener with PIC12C508
AVR Beacon Super Keyer
AVR Digital Voltmeter
AVR Frequency Counter
AVR Signal Generator
AVR-Based Serial Port IR Receiver
Basic Stamp based altimeter
Basic Stamp Lightning Activity Monitor
Buffered PIC chip interface
Build a PIC controlled DDS VFO, 0 to 6 MHz
C-52 EVB Robot Controller
Camera remote control system using Basic Stamp
Connecting AT90S2313 with LCD display 2x16 char and 4x4 keypad
Connecting LED to PIC Micro I/O pins (PDF)
Connecting PIC12C508 8 to 93AA46 serial eprom
DS1820 Arbiter V2.00 Schematic
DS1820 Temperature Sensor Readout Unit
Dual PIC16C84 prototype board
Electronic distance meter based on Motorola 68HC908QY4
Electronic safety lock based on ATtiny26
Embedded system to send e-mails (small TCP/IP stack)
EZ80 single board computer schematic (Z80)
Fan timer based on Motorola 68HC908QT2
Freign vocabulary recollector
FSK modem with PIC16C84
Fully functional PS/2 mouse based on the PIC16F84
Galvanic decoupling of I2C bus
Generate video signals in real-time using a PIC16F84
Giant money counter (PIC16F876)
GPS LCD Display Project
Graphic LCD interface
GSM SMS remote control using AVR microcontroller
Homebrew Basic Stamp project
I2C LCD interface
Illuminate holiday destinations on a world map
Interfacing a 4X4 keypad to a BS2 using a 74922 encoder chip
Interfacing DRAM to AT90S8515
Interfacing EEPROM to a Basic Stamp
Interfacing piezo elements to a microcontroller
Interfacing S-7800A to PIC16F877
Interfacing the MAX186 8 Channel ADC to the BSII
Interfacing the MAX187 ADC to the BSII to measure voltages
Interfacing the PIC16C508
Isolated RS232 for PIC16F84
JDM programmer
Jupiter card programemr
KD7LMO Micro Beacon (PIC18F252)
Kodak DC-20 camera interface (PIC12C509)
Kodak DC-20 camera interface (PIC16F84)
LCD Serial Terminal
LCD to PIC16C54 schematic
Long-period watchdog timer
Low cost Atmel in-system programmer
Mains clock controller using AT89C2051
Microchip PIC ICD (in-circuit debugger)
Microchip PIC ICSP implementation
Microcontroller board using the Atmel AVR AT90S8535
Microcontroller interface for 5KW microwave oven
Microcontroller sensor and actuator interfaces
Microprocessor RS-232 Reset
Microprocessor using Xilinx FPGA
MiniLOGGER V1.0
MMC to PIC16F876 circuit diagram
Motorola 68HC11 evaluation board
Motorola 68K SBC (single board computer)
Multi-chip programmer
Multi-chip programmer for PIC microcontrollers
Network Time Protocol AVR Clock
Night light saver (PIC12C508)
Nixie clock (PIC16F876)
Optical sensor using PIC12C508
Parallel AVR programmer
PC IR receiver based on PIC16F84
PIC 18 programmer (PIC18F458, PIC18F452, PIC18C252, PIC16C745, PIC18F6620, PIC18F6720)
PIC 5x7 display
PIC based packet radio encoder (PDF)
PIC demo board
PIC ICD
PIC ICD in-circuit debugger circuit diagram
PIC LCD and Keypad driver
PIC micro LED projects
PIC micro multiple servo motor interface
PIC micro programmer
PIC micro to ISA bus interface
PIC microcontroller servo motor interface
PIC programmer for serial port
PIC Project #1 - RS232 to I2C Interface
PIC vacuum fluorescent display interface
PIC12C508 Night-light saver
PIC12C508 Phase Controller for 2kW heater
PIC12C509 Gym Timer
PIC12C509 logic gate replacement for nitrogen filler
PIC16C505 IR / wireless remote control
PIC16F84 Based Morse Code Reader
PIC16F84 countdown timer
PIC16F84 CW decoder (PDF)
PIC16F84 debugging terminal
PIC16F84 LED chaser
PIC16F84 line following robot
PIC16F84 miniature real-time controller
PIC16F84 programmer
PIC16F84 pulse monitor with date/time output (ZIP)
PIC16F84 Serial I/O-expander with PicBasic
PIC16F84 stepper motor controller
PIC16F84 tone generator
PIC16F84 tone generator (6-Bit)
PIC16F84 tone generator with source code
PIC16F84 TRIAC / IGBT brightness phase controller
PIC16F84/PIC16F87x-In-System-Programmer
PIC16F873 Digital clock
PIC16F873 remote display
PIC16F873 ultrasonic range meter
PIC16F876 Datalogger
PIC16F877 Programmer And Development System
PIC16F877 to IDE interface
PIC18F252 bootloader schematics
PICADC - a free, PIC based "intelligent" A/D converter
PicCon - Hidden Radio Transmitter Controller
PicoWeb V5.1 (AT90S8515) tiny web server
PIC-Programmer 2
Picxie 2 - 8x8 Animated LED Signboard (PIC16F84) Picxie 2 - 8x8 Animated LED Signboard
PIXpand
POCSAG encoder/decoder
Programmer for the 68HC705C8 MicroController
Programmer PIC16F84,12C50x and EEPROM 24Cxx
Propellor clock (PIC16F84)
PS/2 keyboard keystroke logger based on Atmel 89C2051
RDS Encoder - digital part
Record and play fast 1-bit sound on a PIC micro
RF remote control based on Basic Stamp
Rotating Sprocket Wheel Generator (PIC16F84)
RS 485-RPT Schematic
RS485-like multi-drop bus with half duplex serial protocol
RS485-Version of the SAB80C535-Microcontrollerboard
ScanMate audio activated recorded
Serial to parallel converter using the AT89C2051
Ser-Key 10-Key Serial Keypad Encoder
Simple RS232C Level Converter using Transistors
Smart card programmer
Speaking clock using PIC & ISD device
Speaking doorbell using PIC & ISD device
Speech recognition using HM2007
Talking PIC - based on SP0256
Talking YODA project (PIC16C84)
Temperature controlled based on AT89CX051
Temperature monitor/controller: AVR 2313 / DS1621
Tony Nixons Pocket Programmer (PIC)
Tutorial board for PIC16F84A microcontroller
Ultra low-cost programmer for AT90S family
USB and GLCD expansion board for 8051 SBC
Using an I2C Serial EEPROM with a Basic Stamp 2
Victoria TAFE programmer (based on AT89C2051)
Voice recording and message retrieval system
Way small web server
Whistle detector using 8-pin PIC
Wisp628 ISP Microchip PIC Programmer
WLoader - PIC16F877 application loader / bootloader
Zilog Z80 thermostat embedded web server
dbcv
« Reply #1 on: July 27, 2008, 12:11:09 12:11 »
Cool collection but the link is not working
-Receive: 4460
« Reply #2 on: July 27, 2008, 12:52:08 12:52 »
Links are Working for me.
piclower
-Given: 11
« Reply #3 on: July 27, 2008, 03:21:11 15:21 »
Some  projects are work by other ones not work by its in link diferent
PICPocket
-Given: 48
-Receive: 16
« Reply #4 on: July 28, 2008, 11:59:40 23:59 »
This links to a page which is a collection of links to other sites. I did find some useful stuff but many of the links were "404 Not Found!"
anatom
« Reply #5 on: July 29, 2008, 08:12:28 08:12 »
Several old project I've seen 1000 times and few are useable Undecided
