April 19, 2026, 11:54:33 11:54
Author Topic: [Help] Proton simple program not working  (Read 7791 times)
max
-Given: 1812
-Receive: 52
« on: October 26, 2012, 09:11:12 21:11 »
Hi friends
Here is a very simple led flashing program, when I program the chip with the generated hex file there is no activity, the led is off.
Device = 16F616
Config      IOSCFS_4MHZ, CP_ON, MCLRE_OFF, PWRTE_ON, WDT_OFF, INTOSCIO, BOR_ON
Declare Xtal = 4
Declare Create_Coff = On
Symbol LED = PORTC.3
 TRISA = %11001111
 PORTA = %00000000
 TRISC = %11000000
 PORTC = %00000000
Loop:
 Toggle LED
 DelayMS 1000
 GoTo Loop
flo0319
« Reply #1 on: October 26, 2012, 10:09:19 22:09 »
Any device with analogue inputs will power up in analogue mode. If you intend to use them as
digital types you must set the pins to digital by using the following line of code: -
Declare All_Digital = True
This will set analogue pins to digital on any compatible device.
This is from Proton Compiler Manual.
If you want to use some pins like analogue you can modify ANSEL register (after Power On Reset, ANSEL is 0xFF) "1" means analogue pin and "0" means digital.
EDIT:
  I simulate your program with "'Declare ALL_DIGITAL = true" and with "ANSEL.7 = 0" and now work. you need to use just 1 instruction line
« Last Edit: October 26, 2012, 11:13:35 23:13 by flo0319 » Logged
-Receive: 4460
« Reply #2 on: October 26, 2012, 10:33:36 22:33 »
If you use PDS I think you must set all config registers to a known value, this has been said so many times.
To help you there are known tools to do this, Not to set them is just making a stick to beat yourself up with.
When you compiled the program ....
Did you not see the > Hint [line7] : Ensure that all fuses are placed in the config list, as.........ans so on...
« Last Edit: October 26, 2012, 10:39:50 22:39 by pickit2 » Logged
-Given: 582
« Reply #3 on: October 26, 2012, 10:49:47 22:49 »
Turn off the power up timer I find this sometimes mess's things up
flo0319
« Reply #4 on: October 26, 2012, 11:22:49 23:22 »
why?
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #5 on: October 26, 2012, 11:27:56 23:27 »
When you first start it's a pretty steep learning curve isn't it!
You were close, slightly modded code
'   FLASHER.BAS
Device = 16F616
;Config      IOSCFS_4MHZ, CP_ON, MCLRE_OFF, PWRTE_ON, WDT_OFF, INTOSCIO, BOR_ON
Declare Xtal = 4
 'TRISA = %11001111     ' TRISA set the state of APort
 'PORTA = %00000000     ' PORTA is the data either read or write
 TRISC = %00000000
 'PORTC = %00000000
Loop:
 Toggle LED
 DelayMS 1000
 GoTo Loop
So, in essense
Let the fuses default untill you need to change them.
The "All digital" takes care of the anologue stuff
You don't need to setup the A port
You don't need the PORTC command to write, the Toggle LED will do that for you.
Rgds
Win 7 Ult x64 SP1 on HP2570p
