April 11, 2026, 07:45:37 19:45
Author Topic: how can i remove the previous key for proton?  (Read 16887 times)
arash
« on: December 06, 2005, 08:47:47 08:47 »
Hi all
Do you know how can i remove the previous key for proton?
I ener the wrong key and now it doesent work.
robban
-Given: 34
-Receive: 38
Warrior
« Reply #1 on: December 06, 2005, 03:05:07 15:05 »
´What Proton IDE version do you use?  If You use Metals excellent version, just uninstall it and shoot again. Be sure to manually specify the location of the Proton 2.2.2 Beta compiler when IDE asks for it.
Good Luck
Code Warrior
arash
« Reply #2 on: December 06, 2005, 03:12:52 15:12 »
What do you mean.
I must install it on another dirctory?
arash
« Reply #3 on: December 06, 2005, 03:25:50 15:25 »
I think you beter have la look on this pic.
bayramonur
« Reply #4 on: December 06, 2005, 09:51:02 21:51 »
your compiler version 2.20.You move this file into c:\ and rename GLCtest.bas and try to compile.
Compile so sensitive.Your file dont be existing 8 or more chrecter and location must be so simple.
arash
« Reply #5 on: December 07, 2005, 03:41:35 03:41 »
Hi all.
Finally i make it.I don't know how but it works now.
THANK YOU ALL.
robban
-Given: 34
-Receive: 38
Warrior
« Reply #6 on: December 07, 2005, 10:29:26 10:29 »
Maybe You did nor put any dot in the file name. Impossible for Proton to compile.
Code Warrior
robban
-Given: 34
-Receive: 38
Warrior
« Reply #7 on: December 07, 2005, 10:52:54 10:52 »
For those with a very limited budget, here comes a free C-compiler from Knudsen, a free IDE and .dll:s which has to go to certain place in order to communicate with the parallell port. The GIVEOI.SYS goes to C:\Windows\system32\Drivers. When you'r done with that run the file TESTIO.exe. If You hear a synthesized song, You're on!
I also put a lin k to David Tait: LVPprogrammer. Haven't tested it yet.
The thing You need is a breadbord and a hex-inverter chip besides the PIC of course.
Let me know how Your doing.
Code Warrior
