April 25, 2026, 06:12:49 06:12
Author Topic: PIC PCWHD 4.049  (Read 12518 times)
ahmadexp
-Receive: 12
« on: August 30, 2007, 01:02:12 13:02 »
i have found a trick
tavioman
« Reply #1 on: August 30, 2007, 01:05:13 13:05 »
wow!
- Brain juice -
ahmadexp
-Receive: 12
« Reply #2 on: August 30, 2007, 01:07:04 13:07 »
hi
i have found a new trick
you can download the PCWHD Demo from the ccs web site.
and after that use the the regular PCWH 4.049 from the rapidshare to complete the demo
version.
so you have a complete PCWHD compiler
now you need the PCD.crg file
here is the contains for you
PCD.CRG file
43657
2717
mode:
tes
18266
43888
9000146
best regards
tavioman
« Reply #3 on: August 30, 2007, 01:08:17 13:08 »
10x
- Brain juice -
who
« Reply #4 on: August 30, 2007, 01:50:06 13:50 »
Thanks.
godblessu
-Given: 133
-Receive: 297
« Reply #5 on: August 30, 2007, 01:52:19 13:52 »
I don't get to install PCD.CRG, ccs return invalid crg file message. Embarrassed Embarrassed Embarrassed
Jutzul
« Reply #6 on: August 30, 2007, 04:00:55 16:00 »
Yup, same problem here: "PCD: The CRG file is damaged"  Sad
ahmadexp
-Receive: 12
« Reply #7 on: August 30, 2007, 04:02:34 16:02 »
sorry
i have a typing mistake
chang "tes" in line four to "test"
goodluck
« Last Edit: August 30, 2007, 04:05:40 16:05 by ahmadexp » Logged
godblessu
-Given: 133
-Receive: 297
« Reply #8 on: August 30, 2007, 05:06:47 17:06 »
Thank you, ahmadexp.
But I think PCD is registered in demo version, it has a "d" after version number.
raham
« Reply #9 on: August 31, 2007, 10:08:54 10:08 »
working pcd.crg  file attached
pika
-Given: 274
-Receive: 449
« Reply #10 on: August 31, 2007, 01:35:55 13:35 »
Where is the attached file?
zuisti
-Given: 242
-Receive: 780
« Reply #11 on: August 31, 2007, 03:40:16 15:40 »
version. So you have a complete PCWHD compiler
Hi "ahmadexp",
I cannot download it beacuse I have disabled cokies on my browser for security reasons. Please upload it to rapidshare if possible. Thanks!
and ...you wrote:
"...use the the regular PCWH 4.049 from the rapidshare to complete the demo version."
Why? Simply install and apply the 4 CRGs? (3 from the patch and one from you). IDEupdate?
Please help me!
zuisti
ahmadexp
-Receive: 12
« Reply #12 on: August 31, 2007, 03:45:15 15:45 »
hi dear
pcwhd demo version is only completed for PCD and for pic18 is not coompleted,
that for use the regular pcwh 4.049 to complete it,
about sharing pcwhd demo, sorry i have a slow internet connection (dial up)
zzilot
-Given: 12
-Receive: 20
« Reply #13 on: August 31, 2007, 04:59:38 16:59 »
Move your system time over 30 days ahead and try to run PCWHD.
ahmadexp
-Receive: 12
« Reply #14 on: August 31, 2007, 10:06:28 22:06 »
note that my crg don,t needs the Internet connection only,
about the date i have not seen any problem.
if it was any problem,it's from your pcd.dll library.
best wishes freinds
pak
« Reply #15 on: September 01, 2007, 12:33:52 12:33 »
http://rapidshare.com/files/51140833/CCS_PCWH_4.049.rar
Happy PIC programming...
pak
johnwattcorp
« Reply #16 on: September 01, 2007, 04:01:32 16:01 »
Thank you
Rego
-Receive: 320
The power is back
« Reply #17 on: September 01, 2007, 04:55:25 16:55 »
"THANK YOU" button have been added
Users who post (Thank u) posts will have a (warning) or a (Ban)...
Users who post empty or meaningless posts will be Banned ..
Don't spam our forum with non sense posts just to increase your posts count...
To say thank u (just click "Thank u" button) in any topic instead of posting a new post
Demo for (Thank you) have been added to this topic   (u can test it here)
it will look like this and it appears in every post
Thank you
Smiley ....THE POWER IS BACK.... Smiley
....REGO....
zafzaf82
« Reply #18 on: September 01, 2007, 08:57:41 20:57 »
ed2k://|file|CCS_PCWH_4.049.rar|19415837|5444938E5ED77856104278DC2CC8A17F|h=DXW6QOV33EIVTSARO3LQI7V7ZTLOYNEP|/
zzilot
-Given: 12
-Receive: 20
« Reply #19 on: September 01, 2007, 09:48:03 21:48 »
So whats the difference comparing to this post
http://www.sonsivri.com/forum/index.php?topic=4638.0
darksky
-Given: 183
« Reply #20 on: September 02, 2007, 10:24:54 10:24 »
I have used CCS for a number of projects and been OK.
I am now looking at MikroC.
LuoPan19770708
-Receive: 12
« Reply #21 on: September 03, 2007, 01:59:54 01:59 »
Sir, the crg file is not good for windows vista.
ze_tr
« Reply #22 on: September 03, 2007, 06:50:30 06:50 »
This version also has serious bugs. DS1307 driver that I found on internet was compiled regularly by the version 4.038. However this version did not generate the code for time and date reading rutines. Even it did not give any error or warning Sad Actually arguments were transferred to the subroutiunes as call by value, however parameter lists in these routines were like ...(byte &day, byte &mth,...). I changed the subroutine calling as call by reference and solved the problem.
Another bug was as this: driving a 4 digit 7segment display in a while loop (also in for(;Wink loop) didnot work. When I removed some unused variables (!) solved the problem... (Stupid bug)
ze_tr
« Reply #23 on: September 09, 2007, 11:58:41 11:58 »
For 18F4620
CCS accepts this declaration:
#bit STKFUL=GETENV("BIT:SKTFUL")// S*KT*FUL
But actually it should be
#bit STKFUL=GETENV("BIT:STKFUL") // S*TK*FUL
typo error in the device editor penetrates into the compilation.
Tools->Device Editor->pic18F4620->Register : top 6 registers of SFR ordered by address in reverse manner. This may cause serious problem if you use GETENV("SFR:...") for the registers over there.
You should be carefull when using GETENV and check whether device editor lists the registers at their exact address. Otherwise you have to edit the registers by clicking the mouse on the edit button and start to modify. Don't forget to save (by clicking edit buton, it turns out to save button)
« Last Edit: September 10, 2007, 09:36:42 09:36 by ze_tr » Logged
