May 02, 2025, 10:05:23 10:05
Author Topic: automatic watering system for pots  (Read 5490 times)
esdrufao
-Given: 22
« on: July 30, 2012, 07:13:38 19:13 »
Hello fellow forum, continuing my learning and laziness more than anything makes me have to irrigate 5 plants that have my cousin in the living room, I decided to address a mounting easy both hardware and software.
 Gray matter is a simple assembly PIC 16F628A is enough if I want to extend you other sensors and pumps. The sensor is simpler than a toothpick, two pieces of galvanized wire 6/8cm in length is more than enough.
 No posting the outline that I have not done (is working on the coach), but if I leave a picture of the sensor. Grin
Also I leave the firmware made ​​in PBP
When I finish I go to make the scheme more detailed information.
 Greetings from Sarria, Lugo (Spain)
« Last Edit: July 30, 2012, 07:16:03 19:16 by esdrufao » Logged
chicane
-Given: 17
-Receive: 27
« Reply #1 on: July 30, 2012, 08:42:45 20:42 »
Don't know if you have seen this persons experimental sensor? Thought you might find it of interest
I haven't built it yet, was something I put aside to try sometime.
Take a look
http://www.cheapvegetablegardener.com/2009/03/how-to-make-cheap-soil-moisture-sensor.html
Jef Patat
-Given: 12
-Receive: 37
« Reply #2 on: July 31, 2012, 12:55:51 12:55 »
Take a look
Nice one, that goes on my todo list.  I once built a basic sensor for my mother, think it was based on some Elektor article.  Then she decided to water my super high tech device as well, and that was the end.
esdrufao
-Given: 22
« Reply #3 on: July 31, 2012, 10:01:49 22:01 »
 Hello Chicane , I'm testing the sensors and now works better than I expected.
Soon I'll upload all the information detailed in this show ... have patience which is still in test
jiakoub
-Given: 16
-Receive: 58
« Reply #4 on: August 03, 2012, 09:40:32 09:40 »
i found this on the net it's very simple and works great for me, maybe someone will improve it.
for pads i connect 2 stainless still screws.
 http://www.b2cqshop.com/best/Q00115276-sch.pdf
esdrufao
-Given: 22
« Reply #5 on: August 03, 2012, 10:10:18 10:10 »
It`s very interested  Shocked i go to mount in the breadboard and probe.
thank`s and sorry for my english
jiakoub
-Given: 16
-Receive: 58
« Reply #6 on: August 04, 2012, 07:03:27 07:03 »
For Q1 i put a bc547.
esdrufao
-Given: 22
« Reply #7 on: August 04, 2012, 02:57:15 14:57 »
hiyes i put a BC548c with good results  Grin thank´s for the note
PeeJay
-Given: 31
-Receive: 175
« Reply #8 on: September 10, 2012, 06:11:45 06:11 »
If you can, try and use AC for gypsum block sensors. DC will cause electrolysis and eat away at your electrodes. The easiest way to do it is use a voltage divider, the middle goes to the ADC on your pic, and the + and - go to output pins on the pic. Then after you read the ADC value you swap the two output pins to be the other way around. ie high-low then low-high. I've seen this done with an AVR but I can't find the link.
« Reply #9 on: September 10, 2012, 06:51:04 18:51 »
Anyone know of a very low power, pulse on, pulse off, solenoid valve for water? Very low cost, of course.
-Given: 497
« Reply #10 on: September 10, 2012, 11:43:44 23:43 »
Rather than solenoid, could you use a hobby servo motor?
LabVIEWguru
-Given: 273
-Receive: 593
« Reply #11 on: September 11, 2012, 04:01:56 04:01 »
How about a pump for windshield washer fluid? I bought four of them at a hamfest last weekend for 1 dollar each. Really nice little pumps about one inch diameter and four inches on length. Ford Motor Company.
« Reply #12 on: September 11, 2012, 09:36:44 09:36 »
You could.
But those little plant water tanks you can buy have solenoid valves in them. They run on a 9V battery for four or five MONTHS.
I think they are magnetically latched. You hear a tiny click when it starts the drip cycle.
No idea where to get them.
