April 11, 2026, 12:22:48 12:22
Author Topic: PIC16F1507 & PBP3: missing some register support?  (Read 9102 times)
enzine
-Given: 781
-Receive: 58
« on: February 18, 2012, 09:26:13 21:26 »
Hello friends,
I'm working on a project for low frequency synthesis.
A recently introduced pic (PIC16F1507) contains a 20-bit  Numerically Controlled Oscillator (NCO) that greatly simplify such a project.
The micro PIC16F1507 is supported by the PBP3 (not earlier versions) and with your help  Wink  I'm writing the code for this project.
Much to my surprise I noticed that all its instructions for use of the registries of NCO were not accepted by the compiler!
I did not find any mention of this lack in the WEB.
The analysis of the file PIC16F1507.PBPINC has confirmed that ALL THE REGISTERS ASSOCIATED WITH NCO MODULE  are not present.
I was able to edit this file and now the code is compiled correctly.
My question is this:
this is an exception / error or it may be that other pic is partially supported by the PBP?
P.S.
Sorry for my English but I am of the Latin countries!   Cheesy Cheesy Cheesy Cheesy
PP.SS.
If it can be useful to someone, I'll be happy to post the file PIC16F1507.PBPINC modified.
-Receive: 4459
« Reply #1 on: February 19, 2012, 12:53:28 00:53 »
did you try PSD, as it looks like it supports the NCO resisters.
PSD also seems to have a better following.
enzine
-Given: 781
-Receive: 58
« Reply #2 on: February 19, 2012, 11:09:47 11:09 »
when you say "PSD ", you mean Proton Development Suite?
If yes, this does not seem to support the pic16f1507.
The only basic compiler that supports this pic seems to be PBP3.
Am I wrong?
Ciao
zuisti
-Given: 242
-Receive: 780
« Reply #3 on: February 19, 2012, 11:28:36 11:28 »
PDS supports the pic16f1507 (from version 3.5.2.9)
Edit:
but Proteus does not (yet)
« Last Edit: February 19, 2012, 11:46:17 11:46 by zuisti » Logged
joator
-Given: 248
« Reply #4 on: February 19, 2012, 11:35:16 11:35 »
Yes enzine you are wrong  Smiley
Try the Mikroelektronika's Basic Compiler, it does support the PIC16F1507 among many PIC devices
http://www.mikroe.com
//joator
//Joator
enzine
-Given: 781
-Receive: 58
« Reply #5 on: February 19, 2012, 11:47:22 11:47 »
The PDS is supported the the pic16f1507 (from version 3.5.2.9)
PDS supported microchips:
http://www.protonbasic.co.uk/content.php/1878
16f1507 not present!
What am I doing wrong?
Posted on: February 19, 2012, 12:45:14 12:45 - Automerged
//joator
Thank you joator,
I will try this compiler
Ciao
-Given: 405
-Receive: 545
« Reply #6 on: February 19, 2012, 01:06:53 13:06 »
That link isn't correct
Changes made to Beta version 3.5.2.9
Additions
Added signed variables SByte, SWord and SDword:
SByte can hold a value between -128 to 127
SWord can hold a value between -32768 to 32767
SDword can hold a value between -2147483648 to 2147483647
This is a major change in the compiler's operation and means that existing programs
using Dword variables as signed will need to change them to SDword as Dword
variables are now unsigned.
Added support for devices: 16F1503, 16F1507, 16F1526, 16F1527, 16F1847 and
12LF1840T48A
