April 20, 2026, 10:40:04 22:40
Author Topic: Autodesk Inventor Professional 2008  (Read 7145 times)
vaiduakhu
-Given: 27
-Receive: 349
Hutter
« on: July 19, 2007, 03:39:32 15:39 »
2 DVD | rs.com | 60x50MB | 21x50MB
Autodesk Inventor 2008 New Features
Shaft/Bearing/Keyway Design Accelerators
With the design accelerators in Autodesk Inventor 2008 you can very quickly design complex shaft assemblies without spending valuable time modeling the 3D geometry.
Ribbon Cable
Reduce errors in the design of electronic equipment by incorporating ribbon cables in your 3D digital prototypes.
Sheet Metal
Autodesk Inventor 2008 includes dedicated sheet metal features for flanges, folds, miters, seams and corner reliefs so you can quickly create multiple flanges in a single step.
Drawing Manager
Quickly add dimensions to isometric drawing views with Autodesk Inventor 2008.
DWG TrueConnect
DWG TrueConnect delivers industry leading integration of 2D and 3D design through direct read and write of DWG with full associativity to the 3D design data.
DWF Round Trip
Autodesk Inventor 2008 includes enhanced DWF publishing to simplify file-sharing and increase design security throughout the design review process.
Chain Drive Generator
Simplify the design of chain drives with the chain drive generator in Inventor 2008.
DVD 1:
http://rapidshare.com/files/43813661/aip2k8a.rar
http://rapidshare.com/files/43811531/aip2k8a.r00
http://rapidshare.com/files/43811549/aip2k8a.r01
http://rapidshare.com/files/43811545/aip2k8a.r02
http://rapidshare.com/files/43811554/aip2k8a.r03
http://rapidshare.com/files/43811523/aip2k8a.r04
http://rapidshare.com/files/43811537/aip2k8a.r05
http://rapidshare.com/files/43811943/aip2k8a.r06
http://rapidshare.com/files/43811978/aip2k8a.r07
http://rapidshare.com/files/43811964/aip2k8a.r08
http://rapidshare.com/files/43811966/aip2k8a.r09
http://rapidshare.com/files/43811958/aip2k8a.r10
http://rapidshare.com/files/43812242/aip2k8a.r11
http://rapidshare.com/files/43812234/aip2k8a.r12
http://rapidshare.com/files/43812191/aip2k8a.r13
http://rapidshare.com/files/43812255/aip2k8a.r14
http://rapidshare.com/files/43812208/aip2k8a.r15
http://rapidshare.com/files/43812230/aip2k8a.r16
http://rapidshare.com/files/43812257/aip2k8a.r17
http://rapidshare.com/files/43812228/aip2k8a.r18
http://rapidshare.com/files/43812237/aip2k8a.r19
http://rapidshare.com/files/43812227/aip2k8a.r20
http://rapidshare.com/files/43812836/aip2k8a.r21
http://rapidshare.com/files/43812843/aip2k8a.r22
http://rapidshare.com/files/43812847/aip2k8a.r23
http://rapidshare.com/files/43812852/aip2k8a.r24
http://rapidshare.com/files/43812866/aip2k8a.r25
http://rapidshare.com/files/43812846/aip2k8a.r26
http://rapidshare.com/files/43812841/aip2k8a.r27
http://rapidshare.com/files/43812859/aip2k8a.r28
http://rapidshare.com/files/43812868/aip2k8a.r29
http://rapidshare.com/files/43812862/aip2k8a.r30
http://rapidshare.com/files/43813199/aip2k8a.r31
http://rapidshare.com/files/43813206/aip2k8a.r32
http://rapidshare.com/files/43813213/aip2k8a.r33
http://rapidshare.com/files/43813240/aip2k8a.r34
http://rapidshare.com/files/43813216/aip2k8a.r35
http://rapidshare.com/files/43813204/aip2k8a.r36
http://rapidshare.com/files/43813205/aip2k8a.r37
http://rapidshare.com/files/43813207/aip2k8a.r38
http://rapidshare.com/files/43813227/aip2k8a.r39
http://rapidshare.com/files/43813184/aip2k8a.r40
http://rapidshare.com/files/43813485/aip2k8a.r41
http://rapidshare.com/files/43813501/aip2k8a.r42
http://rapidshare.com/files/43813472/aip2k8a.r43
http://rapidshare.com/files/43813489/aip2k8a.r44
http://rapidshare.com/files/43813480/aip2k8a.r45
http://rapidshare.com/files/43813479/aip2k8a.r46
http://rapidshare.com/files/43813449/aip2k8a.r47
http://rapidshare.com/files/43813473/aip2k8a.r48
http://rapidshare.com/files/43813461/aip2k8a.r49
http://rapidshare.com/files/43813469/aip2k8a.r50
http://rapidshare.com/files/43813664/aip2k8a.r51
http://rapidshare.com/files/43813655/aip2k8a.r52
http://rapidshare.com/files/43813649/aip2k8a.r53
http://rapidshare.com/files/43813662/aip2k8a.r54
http://rapidshare.com/files/43813651/aip2k8a.r55
http://rapidshare.com/files/43813681/aip2k8a.r56
http://rapidshare.com/files/43813665/aip2k8a.r57
http://rapidshare.com/files/43813647/aip2k8a.r58
DVD 2:
http://rapidshare.com/files/43817071/aip2k8b.rar
http://rapidshare.com/files/43814217/aip2k8b.r00
http://rapidshare.com/files/43814209/aip2k8b.r01
http://rapidshare.com/files/43814206/aip2k8b.r02
http://rapidshare.com/files/43814494/aip2k8b.r03
http://rapidshare.com/files/43814516/aip2k8b.r04
http://rapidshare.com/files/43814574/aip2k8b.r05
http://rapidshare.com/files/43814528/aip2k8b.r06
http://rapidshare.com/files/43814533/aip2k8b.r07
http://rapidshare.com/files/43814529/aip2k8b.r08
http://rapidshare.com/files/43814530/aip2k8b.r09
http://rapidshare.com/files/43814579/aip2k8b.r10
http://rapidshare.com/files/43814542/aip2k8b.r11
http://rapidshare.com/files/43816015/aip2k8b.r12
http://rapidshare.com/files/43815988/aip2k8b.r13
http://rapidshare.com/files/43816019/aip2k8b.r14
http://rapidshare.com/files/43816021/aip2k8b.r15
http://rapidshare.com/files/43816026/aip2k8b.r16
http://rapidshare.com/files/43817051/aip2k8b.r17
http://rapidshare.com/files/43817044/aip2k8b.r18
http://rapidshare.com/files/43817062/aip2k8b.r19
http://rapidshare.com/files/43816983/aip2k8b.r20
wessoms
-Receive: 44
« Reply #1 on: July 29, 2007, 09:13:01 21:13 »
Yes it works and has the Cr@ck
Great post!
dazheng
-Given: 43
-Receive: 15
« Reply #2 on: August 26, 2007, 06:38:22 18:38 »
Hi to all, can anyone post only the crack or kegen please...
Thanks in advance'
dazheng  Smiley
Flex
-Given: 201
-Receive: 148
« Reply #3 on: September 04, 2007, 11:25:38 11:25 »
Great things always happening Here,Excellent Software for Mechanical Engineers,Thank you so much for your Links.Working Very well,Excellent Keygen But Content Library will work for 30 Days.Any Idea about this issue.
spurs21
-Given: 35
-Receive: 50
« Reply #4 on: February 13, 2008, 04:56:14 16:56 »
hi friends, like dazheng says i just need the crack, please someone upload it. thanks in advance. regards
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #5 on: February 13, 2008, 07:49:13 19:49 »
There you go , attached
Greetings
