April 11, 2026, 12:23:37 12:23
Author Topic: proton and sdhc cards  (Read 10663 times)
jeanninemtv
-Given: 57
-Receive: 25
« on: January 13, 2012, 12:10:09 00:10 »
hi, i read that the proton sd fille system library supports sd cards, but when i plug a sdhc nothing happens, is any modification necessary to have success with the other ones?
thanks in advance
-Given: 582
« Reply #1 on: January 13, 2012, 06:45:29 06:45 »
jeanninemtv Use this has your test code has I know it works, You may have to change the port settings and pic but it should get you going. Did you use the drawing out the help file to help you build the sd board
   Device 18F45K22
         Xtal =8
  LCD_DTPin = PORTB.0
LCD_RSPin = PORTB.4
LCD_ENPin = PORTB.5
LCD_Interface = 4
LCD_Lines = 2
LCD_Type = 0
     All_Digital = TRUE
LCD_DataUs = 50
    SCL_Pin = PORTC.3
    SDA_Pin = PORTC.4
All_Digital = TRUE
Hserial_Baud = 4800                                         'Setup RS232 port
Hserial_RCSTA = %10010000
Hserial_TXSTA = %00100000
Dim Response As Byte
Dim SD_IO As Byte
Symbol SD_CS = PORTD.2                                      'SPI CS to SD CS (SD pin 1)
Symbol SD_DI = PORTD.5                                      'SPI DO to SD DI (SD Pin 2)
Symbol SD_CLK = PORTD.3                                     'SPI CLK to SD CLK (SD Pin 5)
Symbol SD_DO = PORTD.4                                      'SPI DI to SD DO (SD Pin 7)
Include "TESTCODE_LIB.PBP"     Device 18F45K22
GoTo Over_Sub                                               'Jump over the subroutines
Over_Sub:
    DelayMS 200
Main_Prog:
    Print At 1,1,"INSERT SD OR MMC"
    Repeat
        Response = SD_Init_FS
    Until Response = 0
Open_New_File:
    SD_File_Name = "TESTFILE"                               'File Name, upper case only!
    SD_File_Ext = "CSV"                                     'File Ext, upper case only!
    Response = SD_Check_For_File                            'Check if file already exists
    If Response = 0 Then
        Print At 1,1,"FILE EXISTS - STOPPING"
        Stop
    Else
        Print At 2,1,"OPENING FILE"
         SD_Day = 10: SD_Month =01: SD_Year = 12
         SD_Hours = 21 :SD_Minutes = 06: SD_Seconds = 25
        SD_New_File                                         'Open new file
    EndIf
Write_To_File:
   Print At 2,1,"WRITING TO FILE"
    SD_IO_String = "TEST CODE"
    SD_Write_String_To_File                                 'Write SD_IO_String to file
    SD_Write_Byte_To_File 13
    SD_Write_Byte_To_File 10
Close_File:
    SD_Close_File                                           'Close file
Print At 2,1,"FILE CLOSED"
    Stop
jeanninemtv
-Given: 57
-Receive: 25
« Reply #2 on: January 13, 2012, 11:06:15 23:06 »
wait, you mean the same lib works for sdhc too?  maybe i have the wrong lib... but it's working only with the sd card and when i plug a sdhc card nothing happens ...
i know that the proton lib suppports fat16 file format and sdhc are working on fat32 format so no compatible at all, somewhere i read about a certain swordfish or amicus lib compatible for both but no file found until now Sad and the pbp lib for sdhc is a nightmare but i'm trying to test it -i attach the pbp files here on a compressed file in the next post-
thanks for your response, i will test your code... could you post the pbp include file just for checking if its the same ?
« Last Edit: January 13, 2012, 11:10:38 23:10 by jeanninemtv » Logged
-Receive: 4459
« Reply #3 on: January 13, 2012, 11:23:13 23:23 »
jeanninemtv
until Wizpic gets back to you, when working with sd & sdhc cards & pics, don't you have to format them, with a pc first.
-Given: 582
« Reply #4 on: January 14, 2012, 01:25:07 01:25 »
jeanninemtv the PBP file gets automaticily created when you compile aslong as the code was saved with the same name, EG testcode.bas then the include would be "TESTCODE_LIB.PBP", PDS then would create this.
Bearing in mind SDHC card may not work bigger than 2Gig with pic's and that goes for any compiler, I may be mistaken but I do remember reading some where about it
Pickit you don't have to but I do to be of the safe side
jeanninemtv
-Given: 57
-Receive: 25
« Reply #5 on: January 14, 2012, 01:44:04 01:44 »
pickit: yes i formatted first my sd in w7 before test and worked i generated a file.txt from a internal counter, but i replaced the sd by the sdhc and nothin happened ...  same story with a mini sdhc mounted on his adapter ...  ok i'll test again with the testcode provided by wizpic Smiley  thankx
Posted on: January 14, 2012, 02:39:13 02:39 - Automerged
as i understand (im afraid of beein very wrong  )the .inc file was included in the same folder by you...  i dont know if the pbp file differs from mine ...
-Given: 582
« Reply #6 on: January 14, 2012, 09:06:04 09:06 »
here is the pbp file that got generated. Also the name of your file has to be 8 characters nothing less nothing more and it has to be in capitals too
I use 1GIG cards and it only has 1mb of data on it after logging for 6months
let me know how you get on or need more help
gan_canny
-Given: 101
-Receive: 26
« Reply #7 on: January 14, 2012, 09:38:02 09:38 »
Sometimes if a card isn't working, it is because the mbr has been messed up. A PC windows format is different than a factory format. If you have access to a camera then format your card in the camera and it will restore it to the manufacture's original format. Cards have varying write requirements. The MMC was like RAM and was byte addressed with a write block of 512 bytes ( you could read in bytes but had to write in 512 byte blocks). For MMC the max capacity the addressing could support was 4GB. Commerially few cards were manufactured at 4GB since it involved 4 wafers ( wafer max size was 1GB ) so popular cards were 1GB or 2GB. As the capacity increased the cards starting with SD use a hard disk type addressing (sector LBA type). The addressing scheme remains the same and the larger capacity between cards is a derivative of the sector size. Updates in all situations with cards are read/update /write and therefore the MCU doing the sector write needs enough RAM to buffer the sector. Code written for PIC will be different not only for FAT12 FAT16 FAT32 but also must accommodate the varying sector size as the card capacity increases. It doesn't end there since the electrical interface is also different. Most cards can be forced into SPI mode and often that is the 4 wire interface the MCU will use. SPI is for backwards compatibility but is not a mandate to the card manufacturer. Just to add more variation SPI comes in 4 modes itself dictated by the transitions of the clock and the data. Next there are the pull ups on the SPI interface the faster the I/O the lower the pull up value. Larger cards have tighter timeing constraints. Just as a hard disk identifies its addressing to its host at boot up so does a SD SDHC card. It is up to the host in this case the MCU to deal with this.
« Last Edit: January 14, 2012, 09:48:57 09:48 by gan_canny » Logged
twonuts
-Given: 55
-Receive: 42
« Reply #8 on: January 18, 2012, 10:06:28 10:06 »
Have you tried the Panasonic SD card formatter software?
Also does SDHC cards.
Free from Panasonic web site, page listed below.
http://panasonic.jp/support/global/cs/sd/download/index.html
Versions are available for Windows and Mac OS
« Last Edit: January 18, 2012, 10:10:17 10:10 by twonuts » Logged
jeanninemtv
-Given: 57
-Receive: 25
« Reply #9 on: January 20, 2012, 03:28:20 03:28 »
hi, your lib provided for an unexpected reason dont work for me (compile ok but nothing happened to my sd card 1GB )
i tried another lib and it worked but ...  when i have no sd card in the slot it jumps until the part of opening file ...  (maybe a voltage level when the pins are in the air)  ...
btw i am using just the rdo  ck sdi cs, there are some pins from the connector that are not used
the doubt still remaining is ...  is there any "easy" way to modify that freaky code of the lib to obtain a sdhc compatible lib?
