Hexer379
-Given: 22
« on: December 31, 2011, 05:29:32 17:29 » |
Hello ... @all ... i have a Problem with a simple Testprogram ... (see code fragment) the Output is switching (toggle) ... so the Programm & Pic is working ... i have try 3 LCD´s and 2 PIC´s ... all the same ... the LCD shows nothing ... in simulation (ISIS) it works ... my compiler is :Proton PicBasic v3.5.2.7 ... the LCD should be work in 4-Bit-Mode ! knows everyone where the problem is ?! i´m very confused ... !!! Best Regards , Thomas ... Device = 16F876
Declare Xtal = 10 Declare Watchdog = Off
Declare Slow_Bus On Declare Hbus_Bitrate 100 Declare Hserial_Baud = 9600
Declare Adin_Res 10 Declare Adin_Tad 32_FOSC Declare Adin_Stime 40
Declare LCD_DTPin PORTB.4 Declare LCD_ENPin PORTB.2 Declare LCD_RSPin PORTB.3 Declare LCD_Interface 4
TRISA = %11111111 ADCON0 = %11000001 ADCON1 = %11000000 ADCON1.0 = 0 ' Bit0 is Ref. Ext(1)Or 5V(0)
Dim ChecksumOp As Word ChecksumOp = 139
Symbol AD_5V_In = ADIn 0 Symbol AD_33V_In = ADIn 3 Symbol AD_17V_In = ADIn 1 Symbol AD_Batt_In = ADIn 0
Output PORTC.1 Low PORTC.1 Symbol GoldCap = PORTC.1 Output PORTC.2 Low PORTC.2 Symbol LadenBatt = PORTC.2 Output PORTC.3 Low PORTC.3 Symbol BattStrom = PORTC.3 Output PORTC.4 Low PORTC.4 Symbol MainReset = PORTC.4 Output PORTC.5 Low PORTC.5 Symbol SendActive = PORTC.5
Cls DelayMS 500
loop: Cls DelayMS 150
Print At 1,1,Dec AD_5V_In," ",Dec AD_33V_In Print At 2,1,Dec AD_17V_In," ",Dec AD_Batt_In
DelayMS 500 Toggle LadenBatt GoTo loop
« Last Edit: December 31, 2011, 05:42:30 17:42 by Hexer379 »
-Receive: 4459
« Reply #1 on: December 31, 2011, 08:09:49 20:09 » |
yes what are your fuse settings
Most pic chip code fails to run if fuses are not set up right. you could try ALL_DIGITAL = TRUE
or set the configure fuses using the appropriate registers
-Given: 405
-Receive: 545
« Reply #2 on: December 31, 2011, 09:47:46 21:47 » |
get your lcd working first by using a simple program, then add in your other stuff to the program this should work without adding fuse setting but they are there if needed (remember LVP pin is RB3 ) and check your contrast on the lcd Device = 16F876 ;------------------------------------------------------------------------------- Declare Reminders Off @ CONFIG_REQ = 0 ; Override Compiler's configuration settings Asm- __Config 0x3D3A ;FOSC_HS & WDTE_OFF & PWRTE_OFF & CP_OFF & BOREN_OFF & LVP_OFF & CPD_OFF & WRT_OFF & DEBUG_OFF Endasm- Declare Reminders On ;------------------------------------------------------------------------------- Xtal = 10 All_Digital = True 'PortB_Pullups = True LCD_DTPin = PORTB.4 LCD_RSPin = PORTB.2 LCD_ENPin = PORTB.3 LCD_Interface = 4 LCD_Lines = 2 LCD_Type = 0 'LCD_CommandUs = 2000 'LCD_DataUs = 50 'Initialize LCD DelayMS 150 Cls Loop: Print At 1,1,"test line 1 " Print At 2,1,"test Line 2 " DelayMS 500 GoTo Loop
TomJackson69
-Receive: 63
« Reply #3 on: December 31, 2011, 10:42:55 22:42 » |
@Hexer379 Maybe this will help: This is an example from picBasic which is very close to what you are doing. Using the PIC16F877 A/D Converter. This example displays 3-channels of analog input on an LCD display. link to the project: http://www.rentron.com/PICX1.htmhttp://www.rentron.com/PICX2.htm
Con Rong Chau Tien
Hexer379
-Given: 22
« Reply #4 on: January 01, 2012, 01:55:19 01:55 » |
Hello ... @all ...
thanks for the fast answer !
@bbarney ... i have try this progam ... same result ... :-( i have a poti for contrast ... this is not the problem ...
i have attach the fuse-settings ... this should work i think ...
any other ideas ?!
Best Regards , and a happy new year ... Thomas ...
-Given: 405
-Receive: 545
« Reply #5 on: January 01, 2012, 01:06:07 13:06 » |
Post a schematic and maybe a link to the lcd datasheet might help
Hexer379
-Given: 22
« Reply #6 on: January 01, 2012, 01:44:30 13:44 » |
Hello ... @all ... HAPPY NEW YEAR !!!  here the schematic for the Test in ISIS ... the hardware is the same ...  Best Regards , Thomas ...
gan_canny
-Given: 101
-Receive: 26
« Reply #7 on: January 01, 2012, 02:06:05 14:06 » |
Well, if it doesn't work in the simulator it is rare it will work with the real system. Your circuit works in the simulator but it is not at all guaranteed it will work in the real world but you know that already. Now if the LCD is blank (black all gray or the character positions are just visible above the background gray) the bias supply is often the issue. I see no connection to VDD ( a positive voltage) for the LCD and the bias if I remember is on VEE. The bias is often a negative voltage or possibly ground voltage. If the voltages are correct the character positions can be seen (often all pixels on) and with reasonable contrast to the background (assuming a good bias voltage). Next the LCD needs to initiate correctly but chances are the code you are using is doing this correctly and with the right timing so look first at the VDD and VEE voltages.
-Given: 405
-Receive: 545
« Reply #8 on: January 01, 2012, 02:27:12 14:27 » |
I meant a real schematic showing your real hardware connections isis doesn't show your powers or ground for the chip ,there are 2 of each on that chip you do have them connected ? it also doesn't show wether you have any caps on the crystal mirochip recommends 15pf to 33 pf (closer to 33 is best for 10mhz ) we need a little more than just an isis schematic to help
Hexer379
-Given: 22
« Reply #9 on: January 01, 2012, 03:47:15 15:47 » |
Hello ... @all ...
@gan_canny
when i connect the power , i see all dots ON (black) when i use full contrast ... In real , the PIC with LCD is on a breadboard with is connected to 0V (GND) and +5V ... All power-pins to the PIC are connected ! MCLR is @real connected to +5V over a 3k resistor ! In ISIS VDD to LCD is not connected because i have forgot this ... (but not need in ISIS)
@bbarney In real , the PIC with LCD is on a breadboard with is connected to 0V (GND) and +5V ... All power-pins to the PIC are connected ! MCLR is @real connected to +5V over a 3k resistor ! i use a 10MHz Oscillator with TTL-Output with is connected to CLKIn @PIC ! so i think it is not necessary to use any Cs ...
the wires from PIC to LCD is about 10cm long ... i have test all Pins to LCD with a Oszi ... all Pins have activities ... ?!?!?!?!
this is a very strange Problem ...
Thank you ... Thomas ...
-Receive: 4459
« Reply #10 on: January 01, 2012, 04:02:18 16:02 » |
If your working with a breadboard all your timings maybe upset. Also try moving RS & E to port A or C to see if this helps. you will need to change your code.
Hexer379
-Given: 22
« Reply #11 on: January 01, 2012, 04:05:37 16:05 » |
Hello ...
i have change the 2 Pins to Port C ... now , i have a blinking cursor @pos.1 the rest of the LCD is empty ...
best Regards , Thomas ...
-Given: 405
-Receive: 545
« Reply #12 on: January 01, 2012, 04:49:06 16:49 » |
i use a 10MHz Oscillator with TTL-Output with is connected to CLKIn @PIC ! so i think it is not necessary to use any Cs ... you need the CAPS , probably the only reason it is remotely working at all now is all the stray capacitance from the breadboard taking their place Give us a link to your lcd datasheet
Hexer379
-Given: 22
« Reply #13 on: January 01, 2012, 08:01:57 20:01 » |
Hello ...
caps are installed now ... no change ... The Display is "ALPS hcn-111" the other one is a batron "LCM038-02"
the alps was a testdisplay ... it was functional on many tests with pics ... and it is 100% HD44780-compatible ! lt.google ! (the topic-title is wrong :-( HD77 ?!)
-Given: 405
-Receive: 545
« Reply #14 on: January 01, 2012, 09:31:16 21:31 » |
I just tried 3 different HD44780-compatible 16x2 displays and my code a few post's above and they all worked fine , so you must have bad hardware or a wiring problem somewhere because it's working fine here
make a schematic of how you have it wired up on the breadboard or even a picture
« Last Edit: January 01, 2012, 09:33:36 21:33 by bbarney »
Hexer379
-Given: 22
« Reply #15 on: January 02, 2012, 11:48:42 11:48 » |
Hello ...
thank you ... for all the answers ! ... i have now make a test-circuit board and it works now ... the same config on the breadboard is not working ... VERY STRANGE ! ...
sorry , for all this ...
-Given: 405
-Receive: 545
« Reply #16 on: January 02, 2012, 04:05:07 16:05 » |
probably a bad breadboard , most of them are not that well made
