April 21, 2026, 07:29:19 07:29
Pages: [1] 2  All
Author Topic: [Required]CIMCO Software Suite  (Read 21340 times)
-Given: 582
« on: December 23, 2011, 09:56:52 21:56 »
Does anybody have a copy of this. I did search the forum found to copies of it but the links are dead beacuase there old
Could some one please re-upload
wizpic
-Receive: 4460
« Reply #1 on: December 23, 2011, 10:48:03 22:48 »
version 5.6.73
http://www.fileserve.com/file/Fa4rucp/CIMCO.Software.Suite.v5.60.73-BEAN.rar
I see you stole my bus-pass picture as your avatar
-Given: 582
« Reply #2 on: December 24, 2011, 12:38:43 00:38 »
No that's me on a good day but I've got to say I did think off you when I found it   Grin Cheesy Cheesy Tongue
yahoo
-Given: 56
-Receive: 114
« Reply #3 on: December 24, 2011, 02:15:14 14:15 »
For the latest version 6.10.25 fix does not exist yet but if you need the latest cnc editor only here are the steps to fix it by yourself(the safest way to do it):
1. Download the original installer from cimco: http://www.cimco.com/products/download/CIMCO_61025.exe
2. Install it.
3. Using any hex editor replace the following in the file cimcodnc.exe
file offset:      original content:      replace with:
0xCB85          0F 87                     90 E9
0xCC47          0F 85 70 FF FF FF    90 90 90 90 90 90
0xCC54          0F 8D 63 FF FF FF    90 90 90 90 90 90
0xCC69          0F 84 4E FF FF FF    90 90 90 90 90 90
4. Do the same for the file cimcoedit.exe
0x8FDF5         0F 87                     90 E9
0x8FEB7         0F 85 70 FF FF FF    90 90 90 90 90 90
0x8FEC4         0F 8D 63 FF FF FF    90 90 90 90 90 90
0x8FED9         0F 84 4E FF FF FF    90 90 90 90 90 90
(optional:)
0x215BBC       DEMO Version 0x00   Sonsivri 0x00
5. Enjoy several more years of evaluation of this product.
6. If you really like it or need it for commercial use please BUY it!
Happy Holidays!
« Last Edit: December 24, 2011, 02:21:00 14:21 by yahoo » Logged
hosmis
-Given: 374
-Receive: 244
« Reply #4 on: December 24, 2011, 03:10:54 15:10 »
for @wizpic :
Cimco V6 01.07 Full
DNC Max Server, DNC Max client, MDC Max Client, Cimco Edit, Cimco Data Base Server, Cimco License Server, Pocket PC Client.
x86/x64
Edit :
https://skydrive.live.com/?cid=6c9b337a08661f4d&id=6C9B337A08661F4D%21110
or :
http://www.multiupload.com/HJZDTEVZ3S
« Last Edit: December 24, 2011, 05:53:14 17:53 by hosmis » Logged
-Given: 582
« Reply #5 on: December 24, 2011, 05:17:07 17:17 »
for @wizpic :
Cimco V6 01.07 Full
x86/x64
https://skydrive.live.com/redir.aspx?cid=6c9b337a08661f4d&resid=6C9B337A08661F4D!110&parid=root
It say's this item does not exist not sure what happened there
hosmis
-Given: 374
-Receive: 244
« Reply #6 on: December 24, 2011, 05:52:44 17:52 »
-Given: 582
« Reply #7 on: December 24, 2011, 06:40:26 18:40 »
I've just had quick play with it and wow what a program it is I'm very impressed with.
I've sorted out how to mill a PCB Just need to learn now to draw what I need to, Like cutting out LCD hole on a plastic case and convert it to G-code.
I know how to draw but it's converting it to dxf then convert to G-code but just need to learn how to set it up and cut the depth of it and stuff like that
Good work Hosmis and the others who help too!
wizpic
hosmis
-Given: 374
-Receive: 244
« Reply #8 on: December 24, 2011, 07:01:05 19:01 »
I do not know English language very well sorry.
 my method :
Isis > circuit
Ares > pcb > output - gerber/excellon out file
pcb power tool > gerber to eagle script converter
Eagle > edit > ulp > pcb to gcode (for mach3)
Cimco > gcode test
Mach3 cnc controler > load gcode(nc,tap,txt,...)
Hapy end...
for dxf to gcode :
http://www.christian-kohloeffel.homepage.t-online.de/dxf2gocde.html
« Last Edit: December 24, 2011, 07:09:47 19:09 by hosmis » Logged
-Given: 582
« Reply #9 on: December 25, 2011, 07:30:37 19:30 »
Does the eagle pcb converter allow you to use polygon's in the gerber and the g-code convers ok with a polygon. I know cppper cam can't handle the polygon's
Just downloaded pcb power converter to have a play with,
wizpic
hosmis
-Given: 374
-Receive: 244
« Reply #10 on: December 25, 2011, 08:06:04 20:06 »
Powertool...
http://www.multiupload.com/3ZJ7P3R60P
pcb to gcode (ulp)
http://pcbgcode.org/list.php?12
outsider
« Reply #11 on: March 21, 2012, 01:55:56 01:55 »
What's the password for the skydrive link a few posts above?
hosmis
-Given: 374
-Receive: 244
« Reply #12 on: March 21, 2012, 04:05:12 04:05 »
pw :  feyzalstyle
cncbasher
-Given: 107
-Receive: 51
« Reply #13 on: March 28, 2012, 03:20:57 15:20 »
anyone have the origional download from cimco for version 61025  (cimco_61025.exe)
they seem to have removed it
yahoo
-Given: 56
-Receive: 114
« Reply #14 on: March 28, 2012, 07:00:36 19:00 »
Try using the latest version 6.10.47 downloads:
http://www.cimco.com/products/download/CIMCOEdit6_61047.exe  (ONLY THE EDITOR INSTALLATION)
or
http://www.cimco.com/products/download/CIMCO_61047.exe  (EVERYTHING)
Follow the same procedure above replacing steps 3&4 with:
0xCB85          0F 87                     90 E9
NOTE: The fix for cimcodnc.exe is exactly on the same place like in version 6.10.25 so it is not a mistake that I provide the same information for step 3!
0x901C5         0F 87                     90 E9
0x90287         0F 85 70 FF FF FF    90 90 90 90 90 90
0x90294         0F 8D 63 FF FF FF    90 90 90 90 90 90
0x902A9         0F 84 4E FF FF FF    90 90 90 90 90 90
(optional:)
0x215C14       DEMO Version 0x00   Sonsivri 0x00
I'm still using CimcoEdit5 (5.60.80) and I don't see any reason to upgrade to the latest versions.
Bamsalt
-Given: 359
-Receive: 330
« Reply #15 on: February 21, 2013, 10:54:29 10:54 »
Latest CIMCO v6.20.25 ....
www.cimco.com/products/download/CIMCO_62025.exe
hosmis
-Given: 374
-Receive: 244
« Reply #16 on: February 21, 2013, 11:33:50 11:33 »
From @mambablack , thank you...
for6.20.25 :
http://rapidshare.com/files/3593579659/C%C3%BCmc%C3%B6%20k%C3%BCre%C4%9F.rar
« Last Edit: February 21, 2013, 11:38:58 11:38 by hosmis » Logged
Bamsalt
-Given: 359
-Receive: 330
« Reply #17 on: February 23, 2013, 03:24:08 03:24 »
Unable to get into rapidshare ... Download permission denied by uploader. (0b67c2f5) ...  how about upload to other site, thanks !
gmua
-Receive: 88
« Reply #18 on: July 09, 2013, 06:29:38 18:29 »
I modified CIMCO Edit version 6.20.36 according to yahoo's instructions:
CimcoDNC.exe
0xCBB5          0F 87                     90 E9
0xCC77          0F 85 70 FF FF FF    90 90 90 90 90 90
0xCC84          0F 8D 63 FF FF FF    90 90 90 90 90 90
0xCC99          0F 84 4E FF FF FF    90 90 90 90 90 90
CIMCOEdit.exe
0x90275         0F 87                     90 E9
0x90337         0F 85 70 FF FF FF    90 90 90 90 90 90
0x90344         0F 8D 63 FF FF FF    90 90 90 90 90 90
0x90359         0F 84 4E FF FF FF    90 90 90 90 90 90
(optional:)
0x215C5C       DEMO Version 0x00   Sonsivri.com 0x00
If someone is interested, I am sharing both files.
Thanks yahoo, all the credit is yours...
mick
-Given: 2239
-Receive: 138
« Reply #19 on: July 16, 2013, 10:29:28 10:29 »
direct link for 62036 version
www.cimco.com/products/download/CIMCO_62036.exe
hosmis
-Given: 374
-Receive: 244
« Reply #20 on: October 06, 2013, 10:28:51 22:28 »
62039
http://www.cimco.com/products/download/CIMCO_62039.exe
kürek
http://rapidshare.com/files/2802298906/62%C5%9E39.rar
Posted on: September 01, 2013, 09:49:18 21:49 - Automerged
ÇimçoEdıt70004
b555b
-Given: 73
-Receive: 131
« Reply #21 on: January 10, 2014, 03:13:28 15:13 »
According to yahoo's instructions, I have tried to patch CIMCOEdit.exe version 7.0.25 and it seems to work nicely.
Use your preferred binary editor (I have used PSPad in binary mode) and modify these bytes:
0x94B95         0F 87                90 E9
0x94C57         0F 85 70 FF FF FF    90 90 90 90 90 90
0x94C64         0F 8D 63 FF FF FF    90 90 90 90 90 90
0x94C79         0F 84 4E FF FF FF    90 90 90 90 90 90
I haven't tried to modify CimcoDNE.exe as I'm only using the editor (and its very nice gcode simulator), but the procedure described by yahoo shall also work on that file.
Main improvement in v7, the simulator has now a 'solid animation' mode, i.e. now you can step in the gcode and see the result of each step on the solid result (in previous version, the solid result always displayed the final result of the complete job and only the tool path was animated while stepping or running).
Download link for original version 7.0.25 : http://www.cimco.com/products/download/CIMCO_70025.exe
Of all the GCode simulators that I have tried so far, CIMCO is one of the easiest to use with very good results. For example a lot of simulators fail on helical moves, but no problem with CIMCO (and yes, I use helical moves in my programs...)
« Last Edit: January 10, 2014, 03:25:22 15:25 by b555b » Logged
b555b
-Given: 73
-Receive: 131
« Reply #22 on: January 12, 2014, 06:25:55 18:25 »
I have written a little tool that will allow to apply the solution described by yahoo to any compatible version of CIMCO.
After having installed CIMCO, run my little tool. Select the CIMCOEdit.exe and CimcoDNE.exe executables in the directory where you have installed CIMCO and it will patch them for you.
Tested with 7.0.25 and 6.20.36; shall work with any compatible future version.
All the credit goes to yahoo, I have just automated his method. I don't know how his method works, but I know that it works.
Note that after applying yahoo's method, when your run CIMCO after patching, you will still see a text at the bottom of its main window saying that it is a demo, as well as a text in the about dialog saying that the demo has expired. Don't worry, even with these messages you have now a fully functional CIMCO Edit without expiry date.
EDIT: download link no more valid, go to reply #29 for an updated one.
« Last Edit: September 05, 2015, 12:57:15 12:57 by b555b » Logged
Bamsalt
-Given: 359
-Receive: 330
« Reply #23 on: January 14, 2014, 04:31:46 04:31 »
I have tested this "little tool" with version 7.00.26 ... it works.
Download link for the original version 7.0.26 : http://www.cimco.com/products/download/CIMCO_70026.exe
xor
-Given: 518
-Receive: 311
« Reply #24 on: January 23, 2015, 04:52:00 16:52 »
Pls can anybody reupp this little tool (it seems to be offline)
Patch + install
Freelance handyman...retired after a long time illness
Pages: [1] 2  All
