March 15, 2026, 04:01:32 16:01
Author Topic: servo motor  (Read 7513 times)
hamid9543
-Given: 80
« on: July 08, 2007, 07:07:30 07:07 »
hi
i want to drive 2 servo motor synchronise.2 servo motor (both) move forward or move backward by pic16f877.
hard ware:
 servo motor  (2)
  pic16f877     (1)
software:
picbasic pro
chandra2sekhar2000
« Reply #1 on: July 09, 2007, 09:52:43 09:52 »
hello hamid
just connect the control signal of both the servos to single out put of pic.
later on i will try to provide u the code
hamid9543
-Given: 80
« Reply #2 on: July 10, 2007, 09:30:19 09:30 »
hello chandra2sekhar2000
thanks for yor help.can you explain more about this
hansariii
« Reply #3 on: July 26, 2007, 11:50:48 11:50 »
hello
you need to create a square wave with 1 to 2 ms on for signal pin
chandra2sekhar2000
« Reply #4 on: July 26, 2007, 12:22:54 12:22 »
sorry for late
i hope the given circuit may explain u.
mcr
-Given: 218
-Receive: 23
« Reply #5 on: July 26, 2007, 10:17:31 22:17 »
Use the pulsout command.
Haven't used any servos my self but on many books the use the pulsout command.
Make a quick search on the web, lots of examples (to bad we can not provide links to other forums).
iphone
-Given: 115
« Reply #6 on: July 28, 2007, 03:42:11 15:42 »
sorry for late
chandra2sekhar2000,
Can you share the sourcecode as for starting point ?
hamid9543
-Given: 80
« Reply #7 on: July 31, 2007, 12:10:54 12:10 »
thanks
very good
sherm
« Reply #8 on: July 31, 2007, 01:08:43 13:08 »
You can use the PULSOUT command in PBP to control a servo very easily.
Connect the control line of the servo to RB0 and a centre off SPDT switch wired as active low to pins RA0 and RA1. That'll act as a direction control for your experiment. The following code should give you a good starting point. Adding an extra servo and different control method will be easy after this Smiley
bPos var byte
bPos = 150          'Centre position
loop:
  if PortA.0 = 0 then rotA
  if PortA.1 = 0 then rotB
  pulsout PortB.0, bPos
  goto loop
rotA:
  bPos = bPos + 1
  pause 18
  if bPos > 200 then limitA
  goto loop
rotB:
  bPos = bPos - 1
  pause 18
  if bPos < 100 then limitB
  goto loop
limitA:
  bPos = 200     'direction limit
  goto loop
limitB:
  bPos = 100     'direction limit
  goto loop
This code could be re-written far more efficiently, but it's laid out so that it's easy to understand the process of working with servo's. There's a wealth of information available on the subject if you do a Google search. This should get you started though.
Good luck Smiley
« Last Edit: July 31, 2007, 01:15:13 13:15 by sherm » Logged
engr.humair
« Reply #9 on: December 13, 2007, 01:29:50 13:29 »
Read the PULSIN & PULSOUT function in PBP Manual.They will do the job
Deimos
-Receive: 14
Whatever...!!!
« Reply #10 on: December 13, 2007, 02:45:24 14:45 »
Look at here:
http://www.sonsivri.com/forum/index.php?topic=6901.0
you can use this code, changing the potenciometers by using four push buttons.
Saludos desde Ecuador
Upgraded
« Reply #11 on: December 17, 2007, 07:36:09 19:36 »
Don't power the servos (R/C-servos?) from the same supply as the microcontroller. Servos draw quite a bit of current, and will induce spikes that makes the PIC go funny.
picza
« Reply #12 on: December 18, 2007, 06:38:12 18:38 »
If i want to control 3 dc-motor together.how should i do? and will i use with Chip l239d for 2IC?
Deimos
-Receive: 14
Whatever...!!!
« Reply #13 on: December 19, 2007, 01:22:56 01:22 »
You can use one L293 for controlling two dc-motor, if you want to controll trhee, you need two L293, what do you mean with 2IC?
I2C is a protocoll, you can use PWM to controll the speed of the motors.
PD: the topic is about SERVOMOTORS.
alsabbag
« Reply #14 on: December 25, 2007, 09:39:29 21:39 »
I2C Protocol is used to connect multiple devices together. I don't think it is required for controlling servo motors. PulseOut command can help providing control to 3 servo motors knowing that step duration is much larger than single instruction cycle making the difference in motors start time negligable.
anemon06
-Given: 32
-Receive: 34
« Reply #15 on: January 03, 2008, 12:10:45 12:10 »
step and servo motor application include picbasic and proteus schematic
yobalzal
« Reply #16 on: January 04, 2008, 08:39:24 08:39 »
I hope this will help. Once testing motors controlling experiment, I killed two microcontrollers by the back emf from motors, I found a very simple technique, just put a 100 ohms resistor and a 5V zener diode to protect the micros. It did help a lot.
Cheers...
