-Given: 582
« on: November 28, 2005, 08:15:45 20:15 » |
Has anybody got some code samples in Picbasic pro or Proton code for a 2 button transmitter stright on/off or working code that i could have. If you do not want to share on here PM me and we can talk that way. I NEED you help i don't inder stand aasm/c code I've searched and shearched but no luck Thanks Wizpic
aslan_korhan
-Receive: 60
« Reply #1 on: May 17, 2006, 03:41:27 15:41 » |
Better use PT2262 for Transmitter and PT2272. Its easy and you dont nead microcontroller.
-Given: 582
« Reply #2 on: May 17, 2006, 07:46:50 19:46 » |
Thanks but i have got it all sorted and working now using a pic chip wizpic
Lumos
-Given: 74
« Reply #3 on: May 17, 2006, 09:25:17 21:25 » |
Hi Wizpic what kind of transmitter do you use?
is a pic also used for the receiver?
-Given: 582
« Reply #4 on: May 17, 2006, 09:35:27 21:35 » |
I use a 16F684 smt as transmitter (433mhz) and a 16F628A as receiver and test prove (just using wire as an aireal) 100mtrs plus I have got the correct Aerials on order so i should be able o get further hopefully. wizpic
Lumos
-Given: 74
« Reply #5 on: May 17, 2006, 10:09:13 22:09 » |
hi you have tried to negate one of them ? if this cannot the transmitter be defined high as 1 with the receiver one yet for a long time.
Lumos
-Given: 582
« Reply #6 on: May 17, 2006, 11:07:07 23:07 » |
Not sure what you mean could you explain a bit more my transmitter only transmits for 1.5 seconds then stops until button is pressed again, It can work upto 8 channels (only one at a time). I am in the process of rewriting software to use the same chip for TX/RX with Momentary Outputs ,Latching Outputs. the tx unit only works when button is pressed it is fully working with no problems wizpic
Lumos
-Given: 74
« Reply #7 on: May 18, 2006, 04:38:25 04:38 » |
oops, I have misunderstood ...
do I understand correctly?
transmitter button 1 pressed >> tx >> receiver toggle output 1 (or high or low)
transmitter button 2 pressed >> tx >> receiver toggle output 2 (or high or low)
and so on
lumos
« Last Edit: May 18, 2006, 05:02:09 05:02 by Lumos »
charlie
« Reply #8 on: July 24, 2006, 08:29:25 20:29 » |
here's my code, works gr8, did it for Robotic Control. See if it helps written in PBP 246. regards
« Last Edit: July 24, 2006, 08:31:01 20:31 by charlie »
muddaserniaz
« Reply #9 on: July 25, 2006, 08:27:50 08:27 » |
Not sure what you mean could you explain a bit more my transmitter only transmits for 1.5 seconds then stops until button is pressed again, It can work upto 8 channels (only one at a time). I am in the process of rewriting software to use the same chip for TX/RX with Momentary Outputs ,Latching Outputs. the tx unit only works when button is pressed it is fully working with no problems wizpic plz share your schematic and code for 2 button tx+rx.... !!
-Given: 582
« Reply #10 on: August 01, 2006, 08:35:14 20:35 » |
here's my code, works gr8, did it for Robotic Control. See if it helps written in PBP 246. regards where is your code charle ? it's not there wizpic
nileshhande
-Given: 23
« Reply #11 on: October 16, 2006, 07:41:49 07:41 » |
hi charlie, iam also looking for RF code (16f877a to 628a) plz share it.iam using ST-TX01 -ASK TRANSMITTER MODULE. Thanking you. best Regards.
charudatt
-Given: 53
-Receive: 70
« Reply #12 on: October 16, 2006, 08:08:19 08:08 » |
Sorry for NO CODE,
here is my code.
Just toggle function using PIC and PBP
mizk_electro
« Reply #13 on: October 16, 2006, 12:35:11 12:35 » |
Winpiz, If possible, could you share the schematic please. Thanks.
nileshhande
-Given: 23
« Reply #14 on: October 16, 2006, 06:47:06 18:47 » |
Sorry for NO CODE,
here is my code.
HI CHARUDAT, THANK YOU VERY MUCH FOR THE CODE,I TRIED YOUR CODE BUT ITS WORKING BUT NOT PROPELY..IT WORKS ON MULTIPLE PRESSES..COULD YOU PLEASE CONVERT THIS CODE INTO MANCHESTER.. THANKS... BEST REGARDS
-Given: 582
« Reply #15 on: October 16, 2006, 07:00:39 19:00 » |
I will have to dig it out has i have not played with it for a long time give me a bit of time and i will have a look for it but it's really simple a 5V regualtor,PIC (16f628), 2-8 buttons on portb(held low with resistors and going high when button is pressed) then a 433mhz TX unit, using porta.2 as tx and port.3 for led the rx uint with RX signal coming in on port.2 and the relays go on portb which the realys are fed via transistors hope that helps I will dig them out and get it finished i would like to start and play with them again
cesarman
« Reply #16 on: October 17, 2006, 03:30:29 03:30 » |
HI, maybe this help you. download " http://rapidshare.de/files/35753971/Experimenting.zip.html" Experimenting with the PicBasic Pro Compiler read the section 6 have a good example serial data on RF TX an RX and use librarys on PBP is more simple sample code of TX on RF ' Program AM_TX.BAS ' ************************************************************* ' * For use with EXPERIMENTING WITH THE PICBASIC PRO COMPILER * ' * * ' * This source code may be freely used within your own * ' * programs. However, if it is used for profitable reasons, * ' * please give credit where credit is due. * ' * And make a reference to myself or Rosetta Technologies * ' * * ' * Les. Johnson * ' ************************************************************* ' ' Transmit a two byte code using the AM-TX1-418 or AM-RT4-418 transmitters ' Preceded by a 3 character syncronizing header consisting of "#OK" ' S_BYTE, holds the byte to be transmitted ' RC_ID, holds a unique transmitter number ' ***********************************************************************
Include "Modedefs.Bas"
' ** Setup the Crystal Frequency, in mHz **
Define OSC 4 ' Set Xtal Frequency
' ** Declare the Variables ** Counter Var Byte ' For-next loop variable S_Byte Var Byte ' The data byte to be transmitted RC_ID Var Byte ' The transmitter ID
' ** Declare the Constants ** B1200 Con 17197 ' Inverted 1200 baud for SERIN2 B2400 Con 16780 ' Inverted 2400 baud for SERIN2 B4800 Con 16572 ' Inverted 4800 baud for SERIN2
RC_ID=21 ' Transmitter number is 21 Main: For Counter= 0 to 255 S_Byte=Counter ' Transfer COUNTER into S_BYTE Serout2 PortA.0,B2400,["#OK",RC_ID,S_Byte] ' Send out the 2 bytes preceded by a 3 chr header Pause 100 ' Pause so we can see whats happening at the receiving end Next Goto Main
mizk_electro
« Reply #17 on: October 17, 2006, 05:31:42 05:31 » |
I will have to dig it out has i have not played with it for a long time give me a bit of time and i will have a look for it but it's really simple a 5V regualtor,PIC (16f628), 2-8 buttons on portb(held low with resistors and going high when button is pressed) then a 433mhz TX unit, using porta.2 as tx and port.3 for led the rx uint with RX signal coming in on port.2 and the relays go on portb which the realys are fed via transistors hope that helps I will dig them out and get it finished i would like to start and play with them again Thanks Wizpic & Cesarman
« Last Edit: October 17, 2006, 05:35:12 05:35 by mizk_electro »
