March 17, 2026, 04:53:00 04:53
Pages: 1 2 [3]  All
Author Topic: Proton+ Supports More PICs here !!  (Read 45286 times)
t_anjan
« Reply #50 on: February 08, 2006, 01:46:17 13:46 »
Am I supposed to enter the Activation Code everytime I compile a program?
And, in the keygen what r the "Full Serial 2" and "Recharge" codes for?
Am I missing a point here?
-Given: 582
« Reply #51 on: February 08, 2006, 09:27:39 21:27 »
Dip
I have complied your program with out any problems what's supposed to be wrong with it i have not tried your program as i do not have an Nokia LCD to try it, so if your cod does not run then you you need to go through and check it over. give us more detial has to whats happening when you compile and what the error is we are not mind readers. we are also no here to wrie code for you we can assit you in writing your code but no one will write it for you.
T anjan
no you should not enter the activaion code every time you goto compile i had this problem once but can't remember what i did to resolve it but i'm sure one will know
Remember Metal has worked very hard to get this far with Proton so insted of saying ERROR/BUG say THANKS for doing a great job Metal as done,
wizpic
t_anjan
« Reply #52 on: February 09, 2006, 09:15:42 09:15 »
Quote from: Wizpic
T anjan
wizpic
Well, glad to know that someone else had the same problem and managed to solve it. If only someone could provide me with the solution. I followed instructions exactly as given in the Readme file. But everytime I compile a program, it asks me for the activation key, which when I enter using the keygen's "Full Serial 1", it gets accepted. But if I compile the same program again, again the actiavtion dialog comes up.
leppod<-
« Reply #53 on: February 17, 2006, 07:24:58 07:24 »
Hi !!
review page 2, (NOTAS A LA INSTALACION Y ACTIVACION DE PROTON DS DE MetaL.doc ) you will find the correct way to install.-
good luck!!.
wacksbaby
« Reply #54 on: March 14, 2006, 03:41:36 03:41 »
Hi MetaL,
Thanks for this wonderful software, i am a PICBasic Pro+MCSP user but i find it more convinient to use the PDS.
Thanks bro
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #55 on: June 12, 2006, 08:30:44 20:30 »
Thank you so much Metal
Licensing instructions OK.
Great Work !!!!
So long
Francisco
dine
« Reply #56 on: July 16, 2006, 10:39:15 10:39 »
thank you for share and upload like greate one...........
kathir
« Reply #57 on: July 20, 2006, 11:30:33 23:30 »
Quote from: metal
It did take me a long time to provide this one in deed, any way, hope you like it Smiley
Download From Rapidshare
P.S. Read the text file first...
every thing ok . but i am getting file opening error when i tries to compile
i get the message as follows pl help me
cannot open file proton\crownhill\samples\vu_meter.bas
pl help me
Dom
-Given: 65
-Receive: 32
« Reply #58 on: July 21, 2006, 04:41:52 16:41 »
With the version of Metal, you must place your project in a short folder like "c:\Pic_project" and the name of the file must be short (DOS format: 8+3)
Regards, Dom
Dom
kathir
« Reply #59 on: July 21, 2006, 06:19:17 18:19 »
Quote from: Dom
Regards, Dom
 thanks  it is working . but i want proton  basic compiler  for pic 18f4550 pl
8ball
« Reply #60 on: July 24, 2006, 11:07:12 11:07 »
Quote from: kathir
yes
me too.
kathir
« Reply #61 on: July 25, 2006, 01:06:08 01:06 »
Quote from: 8ball
yes
me too.
i need  latest version  pic basicv compiler which supports  18f4550 also
can any one help me
pak
« Reply #62 on: August 08, 2006, 07:02:36 07:02 »
Hi Metal,
           Thank you for your support,
           Can you please post edonkey link because I cannot access Rapidshare.
Thank man,
pak
niky
« Reply #63 on: August 18, 2006, 12:30:22 00:30 »
thank you metal ,I use on XP SP2 and works fine
Thank you again for your effort
niky
Yanch
« Reply #64 on: January 19, 2007, 12:40:18 12:40 »
Hi? Metal!
Please  Share link fo "Proton+ Supports More PICs here !!" to http://rapidshare.de... - I can't download that soft.
P.S. I use same yea agou "Proton+" !!!!!
cosmomen
« Reply #65 on: February 23, 2007, 12:49:40 12:49 »
Hi!
Can somebpdy post here a working link for proton version which supports 18Fxxx
Thanks in advance!
robban
-Given: 34
-Receive: 38
Warrior
« Reply #66 on: April 13, 2007, 02:18:36 02:18 »
Hi!
Everybody who tries to compile PIC:s which is not included in Metal Proton, I suggest You download POSEK:s 3 version and copy the inc. folder to Metals inc. folder. BTW, is Metals version available somewhere?
« Last Edit: April 14, 2007, 08:11:34 08:11 by robban » Logged
Code Warrior
Pages: 1 2 [3]  All
