April 29, 2026, 08:20:33 08:20
Author Topic: I suggest You a great application...  (Read 4986 times)
gonzogonzo
-Given: 79
-Receive: 49
« on: June 24, 2007, 05:48:15 17:48 »
I have tested a great application "Thin*stall".....
With this application it is possible run application from USB drive and
is not necessary install them with standard installer: simply run
them from a file from USB sticky.
It's work great with Ea*gle, Prot*eus, Orc*ad, Puls*onix, Aba*com, Alti*um etc.
Great all eletronics software in a single USB key: search it it's
one of the best application that I see.
trampe
-Given: 527
-Receive: 261
« Reply #1 on: June 24, 2007, 09:26:32 21:26 »
Any idea where I can get this great application?
gonzogonzo
-Given: 79
-Receive: 49
« Reply #2 on: June 25, 2007, 09:20:02 09:20 »
If You don't want pay try this:
http://rapidshare.com/files/33648327/hinstallPE.rar
avr2000
« Reply #3 on: June 25, 2007, 02:06:15 14:06 »
Unfortunately threat has been detected in the upper package: Trojan.Small in ThinstallPatch.exe
Can you provide clean patch for this product?
gonzogonzo
-Given: 79
-Receive: 49
« Reply #4 on: June 25, 2007, 07:48:45 19:48 »
 Embarrassed You have right there is a trojan....
I have used original program not cracked but after your segnalation i have test not original version.
After use infected crack if You remove this there are not problem and program work ok and all
file generated and in other location are ok and no net traffic.
I think that antivirus have a false detect because crack write a email address for license (or similar this);
unfortunally i don't know other link but i suggest You to crack executable in  a bad computer and then
import this in Your PC and test it and file result with antivirus...
If You test say me more...
nikhilele
-Receive: 22
« Reply #5 on: July 08, 2007, 08:12:05 20:12 »
is there any way to use software when we cannt install them on pc
Actually I dont have administrative rights on my PC
so i am unable to install softwares..
