March 13, 2026, 05:48:55 05:48
Author Topic: Isolated mains voltage measurement  (Read 7163 times)
max
-Given: 1807
-Receive: 52
« on: September 10, 2011, 04:30:15 04:30 »
Hi friends,
How to measure isolated mains voltage without using isolating transformer?
« Last Edit: September 13, 2011, 11:08:51 11:08 by max » Logged
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #1 on: September 10, 2011, 07:19:19 07:19 »
Opto-isolator.
chandra2sekhar2000
« Reply #2 on: September 10, 2011, 01:21:23 13:21 »
go though with the idea of the clamp meter.if u want to implement a circuit for that use,some windings like a coil,and use adc, microcontroller.
microkid
-Given: 46
-Receive: 23
« Reply #3 on: September 10, 2011, 01:27:25 13:27 »
There are Analog opto isolators (single chip) available.
Another way is to convert the signal to digital and use regular opto isolators
MicroKid
Never Never Never giveup
max
-Given: 1807
-Receive: 52
« Reply #4 on: September 10, 2011, 05:37:20 17:37 »
microkid,  analog opto isolators are expensive, I need low cost solution.
any low cost example for the second option.
max
microkid
-Given: 46
-Receive: 23
« Reply #5 on: September 11, 2011, 03:15:48 03:15 »
Any simple Voltage to frequency converter will do the job. (For example a 555 timer can be used as voltage to freq. converter)
TomJackson69
-Receive: 63
« Reply #6 on: September 12, 2011, 12:46:55 00:46 »
@ max
Your question maybe best answer by this question on the edaboard.com:
measure mains voltage isolated and
Re: What is the best way to measure main voltage with isolat
And here is link:
http://www.edaboard.com/thread158728.html?vm=r
Your question seems very simple but rather complex. It all depend on how you want to used for and your application.
Tom
Con Rong Chau Tien
