March 07, 2026, 05:35:22 05:35
Author Topic: ICD3 HELP NEEDED.  (Read 7412 times)
Manuel
-Given: 784
-Receive: 205
« on: June 14, 2011, 05:34:14 17:34 »
Hi you all,
i am facing a great problem.
Story beginning:
ICD2 do not work on WIN7 x64 so i had to get ICD3.....
The Problem:
The ICD3 CLK line can not carry current....it seems as if there is a series resistor on the ICD3 BOARD.... and i am not able to look for it.
When i refer to current i mean processor CLK itself + SI2312 mosfet...that's all..... The ICD2 was able to work properly with same design with no problem.
Can anyone help me in solving this issue?
Best regards.
Manuel.
hate
-Given: 156
-Receive: 355
« Reply #1 on: June 15, 2011, 10:23:15 10:23 »
Remove the internal resistor or make an external buffer for the pin.
Regards...
Regards...
j0k3r
-Given: 44
« Reply #2 on: June 15, 2011, 11:38:05 11:38 »
Is this you need?
http://ww1.microchip.com/downloads/en/DeviceDoc/ETN29_MPLAB_ICD%20_%20VPP_CURRENT_SINK.pdf
Manuel
-Given: 784
-Receive: 205
« Reply #3 on: June 15, 2011, 05:58:43 17:58 »
Hi MAN:
problem solved....can help you all probably and maybe many other people worldwide.
to HATE:
nice suggestion....but with no subject at all! what resistor? do not joke please. it was a really serious topic!
anyhow, thank you for your hidden suggestion. ;-)
to j0k3r:
thank you for digging....i got it already yesterday......it can help many people to improve VPP current in ICD3...but it's not related to mine problem.
PROBLEM:
ICD3 can not drive even 2.2nC on CLK line!
SOLUTION (TAKE NOTE!!!):
ICD2 last version can do it correctly and work even with WIN7 x64 ! I will update version of ICD2 tomorrow!
ICD2 other previous versions can manage correctly programming but there no driver for WIN7 x64 and will never be released!
PICKIT 2 can not drive current on CLK line so do not work if you charge it even with just 2.2nC.
PICKIT 3 work great with changed programming lines.
ICD3 same problem as PICKIT2....waiting for a resistor patch solution....if found i will update you all here.
Thank you to you all!!!!
take care.
Manuel.
hate
-Given: 156
-Receive: 355
« Reply #4 on: June 17, 2011, 12:38:07 12:38 »
to HATE:
What kind of a joke did u make out of my comment? U said there seemed to be a series resistor and I suggested removing it, what resister else could it be??? And for the buffering part I meant a simple buffer like 74HC(T)244 or similar according to ur needs. What further information do u need before google-ing for some actual application?
Regards...
Regards...
Manuel
-Given: 784
-Receive: 205
« Reply #5 on: June 17, 2011, 05:15:12 17:15 »
Dear Hate,
with......"it seemes as if there is a series resistor".... i ment that there is a current limit...maybe thank's to a resistor.....but i have no idea which R it is....so i was asking if anyone could help me in checking... Got it now?
thank you Hate!
take care.
manuel.
hate
-Given: 156
-Receive: 355
« Reply #6 on: June 18, 2011, 10:51:06 22:51 »
Can u pls post a schematic of what u are trying to do? And what does 2.2nC mean? 2.2nF Capacitor or 2.2n Coulomb charge? Basically if u have a capacitor on the clock line in the external circuit, u can use a series resistor between the PIC port and the external capacitor and connect the clock signal directly to the pin. But that depends on what u are trying to do, I require more information to be of further help.
Regards...
Regards...
