October 16, 2025, 09:19:40 09:19
Pages: 1 [2]  All
Author Topic: Power Supply 12bit  (Read 20543 times)
Kabron
-Given: 68
-Receive: 145
« Reply #25 on: October 02, 2011, 04:12:07 16:12 »
I did Proteus Simulation of the 12bit PSU(I'll upload it later).
It seems that toti is afraid to show the final version as in Youtube.
Only one mode display realized, wrong BaudRates, wrong PS2 protocol, no KBD controll.
Invain to repeat the design. He'd also post Youtube links on pickbasic.org and edaboard with no sources.
« Last Edit: October 02, 2011, 04:15:14 16:15 by Kabron » Logged
pertican
-Given: 436
-Receive: 1130
« Reply #26 on: October 02, 2011, 06:42:39 18:42 »
I am currently designing the digital part with Mega16. Smiley
soon...
Digital part includes :
16 bit analog to digital(Without any converter D/A IC)
glcd 128x64 ks0108.
touchscreen for change outputs.
Thermometer.
fan.
« Reply #27 on: October 02, 2011, 08:08:48 20:08 »
@Pertican, I am confused with your schematic. Is it switching or linear power supply? Where is the connection between AGND and GND? Is that true there is GND connected at the junction of R3 + R4?
pertican
-Given: 436
-Receive: 1130
« Reply #28 on: October 02, 2011, 09:05:34 21:05 »
this is linear but you can use switching instead
transformer - rectifier - filter
AGND = Analog gnd or power gnd
GND = digital gnd
ps: this is old version schematic and i think have problem.
new schematic is here: (attach)
www.sonsivri.com/forum/index.php?topic=37575.msg122376#msg122376
block diagram:
www.sonsivri.com/forum/index.php?topic=37575.msg122450#msg122450
« Last Edit: October 02, 2011, 09:09:40 21:09 by pertican » Logged
pertican
-Given: 436
-Receive: 1130
« Reply #29 on: October 03, 2011, 11:12:26 11:12 »
ok!
Digital part v1.0
Attach (Simulation + C Code)
If anyone has new ideas. say to add.
« Last Edit: October 03, 2011, 11:15:04 11:15 by pertican » Logged
« Reply #30 on: October 03, 2011, 03:34:39 15:34 »
How about real V / I readings?
pertican
-Given: 436
-Receive: 1130
« Reply #31 on: October 04, 2011, 11:42:14 11:42 »
In The Analog Schematic
the output of the first OpAmp you can read I/V.
If you see the schematic
(simulation_voltage_control)
Output Of U2B = Vout / 11 (min 0v max 3v or 4v)
(simulation_Ampere_control)
Output Of U2B = Iout (min 0V=0A & Max 4v=4A)
PS: For Simulation TouchScreen In Proteus You Need This Model
http://www.tanu-sha.narod.ru/ts128x64.html
« Last Edit: October 04, 2011, 11:49:19 11:49 by pertican » Logged
« Reply #32 on: October 04, 2011, 04:28:50 16:28 »
Hi Pertican,
I mean the microcontroller read the real V / I values so it can do a closed loop control.
I quickly looked into your code, I think it is open loop control - won't give a good load regulation. Sorry if I am wrong.
pertican
-Given: 436
-Receive: 1130
« Reply #33 on: October 09, 2011, 02:12:19 14:12 »
Yes , We Can Use the ADC, microcontroller.
Pages: 1 [2]  All
