Proton: LookdownL + Array - Sonsivri
May 13, 2026, 11:18:58 23:18
Author Topic: Proton: LookdownL + Array  (Read 8862 times)
Basicpic
-Receive: 43
Welcome! www.picbasic.ru
« on: February 16, 2011, 06:06:17 06:06 »
I have a one question.
I have a code:
DIM ADC AS WORD
DIM G AS BYTE
DIM config[16] AS WORD
Displaying:
G = LOOKDOWNL ADC, <= [ 0, config[1],config[2],config[3],config[4],config[5],config[6],config[7],config[8],config[9],config[10],config[11],config[12],config[13],config[14],config[15],config[16] ]
GOTO Displaying
Why the compiler (3.5.0.6/3.5.1.2) return error - ERROR[Line 210]: Comma missing, or command terminated incorrectly!
With PBP i use this:
 ADC var WORD
 G var BYTE
config[16] var WORD
Displaying:
G = LOOKDOWN2 ADC, <= [ 0, config[1],config[2],config[3],config[4],config[5],config[6],config[7],config[8],config[9],config[10],config[11],config[12],config[13],config[14],config[15],config[16] ]
GOTO Displaying
and not any errors. Why? Proton help have no any info about arrays with LookdownL. Help me, please
-Receive: 4459
« Reply #1 on: February 17, 2011, 03:52:35 03:52 »
maybe your syntex is wrong Config is a protected word in Proton, It in the Manual.
Also why are people saying Help don't work. I have seen this asked in Crownhill forum too.
« Last Edit: February 17, 2011, 04:00:44 04:00 by pickit2 » Logged
Basicpic
-Receive: 43
« Reply #2 on: February 17, 2011, 10:10:51 10:10 »
I know about F1. But my compiler help (.pdf) have no any information about lookdownl + arrays with constant index.
Syntax
Variable = LookDownL Index, {Operator} [ Value {, Value�etc } ]
Overview
A comparison is made between index and value; if the result is true, 0 is written into variable. If
that comparison was false, another comparison is made between value and value1; if the result
is true, 1 is written into variable. This process continues until a true is yielded, at which time the
index is written into variable, or until all entries are exhausted, in which case variable is unaffected.
Operators
Variable is a user define variable that holds the result of the search.
Index is the variable/constant being sought.
Value(s) can be a mixture of 16-bit constants, string constants and variables. Expressions may
not be used in the Value list, although they may be used as the index value. A maximum of 85
values may be placed between the square brackets, 256 if using an 18F device.
Operator is an optional comparison operator and may be one of the following: -
= equal
<> not equal
> greater than
< less than
>= greater than or equal to
<= less than or equal to
Ahmad_k
SCG Moderator
-Given: 179
-Receive: 1299
« Reply #3 on: February 19, 2011, 01:45:57 01:45 »
Why you didn't just use this syntax :
G = config[ADC]
it is simple and equivalent to your code
you error is because the symbol  "<="
fernandodiaz
« Reply #4 on: March 02, 2011, 09:42:22 09:42 »
Hi  i have problems whith proton plus in this code:
Device 12F510
Dim x As Byte
x = adin 0    "error no support 12 bit"  but this contain some a/d internals
too problems lookup command   , other alternative CDATA dont support
up 100 > ...   [1,2,3,4,5...... ,_
                     150,151...]
with much values dont work fine in this prosessor
some idea?
-Receive: 4459
« Reply #5 on: March 02, 2011, 05:56:20 17:56 »
maybe 12F510 has A/D internals, But proton don't support that device.
see page 44 of manual.
« Last Edit: March 02, 2011, 05:59:00 17:59 by pickit2 » Logged
FranzW
-Given: 589
-Receive: 81
« Reply #6 on: January 31, 2012, 10:16:17 22:16 »
Perhaps I should have started a new thread, but I don't know how to do it.
I need to count fast incoming encoder pulses by means of interrupts on PORTB.7. Does somebody know what must I do in order to place my interrupt routine at ORG 4, the interrupt vector address? If I use ORG 04 in the program below, Proton issues the error message: �Overwriting previous address contents (0004)�
Part of the program can be seen below.
Device = 16F877A
Declare Xtal = 4
All_Digital = true
Dim Pulses As Word 'To store RB7 interrupts
TRISB = %11111001
' OTHER VARIABLES, TRIS, etc. WILL BE DECLARED HERE.
'Making place to save the required registers during the interrupt.
'Since I didn�t find anything about this in the Proton manual,
'I created room to save the registers, as stated in the PBP V 2.46 manual.
Asm
     W0 equ 0x0020 'bank 0 place For W
     S0 equ 0x0021 'bank 0 place for STATUS
     P0 equ 0x0022 'bank 0 place for PCLATH
     W1 equ 0x00A0 'bank 1 place for W
     W2 equ 0x0120 'bank 2 place For W
     W3 equ 0x01A0 'bank 3 place For W
EndAsm
GoTo Program 'Jump over the interrupt routine
'*************Interrupt routine
Asm
   'Save registers
   Movwf W0
   Swapf STATUS, w
   Clrf STATUS
   Movwf S0
   Movf PCLATH, w
   Movwf P0
   'The interrupt code will be placed here.
   'Restore registers
   Movf P0, w
   Movwf PCLATH
   Swapf S0, w
   Movwf STATUS
   Swapf W0, f
   Swapf W0, w
   Retfie
EndAsm
Program:
'Program code is placed here.
-Receive: 4459
« Reply #7 on: February 01, 2012, 04:40:30 04:40 »
To start a new topic select "New Topic" in section you want to post in.
you will see new topic button to the right
Sonsivri > Electronics > Pic Basic Languages This Topic
