April 22, 2026, 07:50:49 19:50
Author Topic: ICL7106 based Multimeter  (Read 7416 times)
king
-Receive: 21
Jack of All But Master of One
« on: December 12, 2010, 01:00:59 13:00 »
I have read PDF of ICL7106 but till now i have not understand that how ICL7106 converts 0-200mv signal in to actual voltage for example
if i want to measure voltage by multimeter probs =150VDC so for this I have to stepdown this voltage in to mv which can be done by the image which i have attached and that 0-200mv signal feed into ICL7106 so what is the calculation this ic has performed internally to get the actual voltage and if you see the image that it has total four steps (increase by factor of 10) and in each step we will get 0-200mv so how it can judge the step (10^1,10^2,10^3,10^4)
If any body has knowledge about it then please share it.
titi
-Given: 4126
-Receive: 862
« Reply #1 on: December 12, 2010, 02:55:04 14:55 »
Since ICL7106 give a visual range of -1999 to +1999 (2000 points), you need to fixe a voltage range to have the maximum of 1999 round to 2000 to simplify.
Example:
  you want measuring 150v DC.
  So the immediate range above 150v is 200v.
  You need to do a input attenuators, so when you put 200v you need have 200mv to the input of the ICL7106.
  You need have to activate the good decimal point on the LCD according visual range.
  On range 200v with 2000 pts you have the visual range 199.9 v, so the decimal point must be activated after the first digit.
with other range, it is the same principe:
range 0-2v     : max 1999 mv or 1.999 v
range 0-20v   : max 19.99 v
range 0-200v : max 199.9 v
range 2000 v  : max 1999 v
Here a link this some formulas to calculate the value for R1 and R2 resistor divisor.
Near "Input Attenuators"
http://www.eidusa.com/Electronics_DPVM.htm
Best Regards.
