April 29, 2026, 07:04:16 07:04
Author Topic: Could you help me about RS232 Isolate  (Read 4602 times)
pecpys
« on: May 14, 2007, 05:34:39 05:34 »
I make project by use PIC communicate to GSM Modem by use MAX232
When I test RS232 port with PC, the board is work OK.
But when I connect board to GSM Modem board was broken.
I check the error is IC MAX232 fail.
I think is because of the GSM Modem.
I check voltage between ground (on pin5 of GSM modem and Pin5 on board's 232 ports) is about 125 Vac. and 0 Vdc. and I see Vac in every pin on GSM modem.
Why the modem has AC in the pin?
and How to correct it?
If I you isolate circuit it will OK?
Could you recommend circuit for us. (I not use CTS and RTS with Modem)
Thanks you.
zuisti
-Given: 242
-Receive: 780
« Reply #1 on: May 14, 2007, 08:45:16 08:45 »
Why the modem has AC in the pin? and How to correct it?
Hi pecpys!
Your problem is definitely a grounding error.
Beacuse in this case the grounding is correct throught your serial cable.
This points to the problem: you are worked here without a common ground line.
The correction: make it!
Whereby? I don't know your circuits/cables, you can solve the problem :-)
Probably (but insecure :-) you must interconnect the grounds !!!
Yes, the isolating is an other solution.
However, to make this, the schematics are a must.
You can see a lot of examples on the net.
Hope this helps!
zuisti
Silent_Thunder
-Given: 57
-Receive: 20
« Reply #2 on: May 14, 2007, 11:07:03 11:07 »
If you would like to isolate the RS232 from your circuit have a look at the attached chematic it might help you
samir
-Given: 27
-Receive: 21
« Reply #3 on: May 15, 2007, 08:37:50 08:37 »
Thanks you.
