April 28, 2026, 12:20:11 00:20
Author Topic: PIC with Ethernet And I2C  (Read 6359 times)
orpheedulogis
« on: November 19, 2010, 05:22:13 17:22 »
Hi all
Actually I use mikrobasic,  PIC4553 ("Soft_i2C") and Proteus for simulation.
Now, I would like to have a PIC, if possible with a 12 bits ADC, with Ethernet and hardware I2C.
This is for my electric motorcyle ( www.motoelectrique.unblog.fr ) but, in fact, I want first to learn how to do for ethernet connections so I can make new (RFID) projects.
That's why I'm asking for best PIC you can propose to me.
Also, I have a (small) problem actually.
My actual electric  motorcyle project do many things and I would like "lighten" for increasing speed. For example, I would be interested to use a small PIC like 12F675 in slave I2C mode so it can send speed information or other things when asked by I2C (instead of using PIC4553 interrupt to do so).
Thanks for help
Posted on: November 19, 2010, 05:49:30 17:49 - Automerged
The first thing I can see that's it's seems impossible to use ethernet and I2C  Embarrassed
Is it so ?
Suky
« Reply #1 on: November 19, 2010, 06:35:53 18:35 »
Search for it yourself:  Wink
http://www.microchip.com/maps/main.aspx
orpheedulogis
« Reply #2 on: November 19, 2010, 07:12:16 19:12 »
Thanks for your answer
Nice link.
But it's not very clear for me: what did I need exactly to have ethernet and I2C capacities ? two SDA/SCL, right ?
It would be fine if I could find small package PIC with this so I can have a master PIC and a slave one on same board, one to prepare ADC values, speed value ... and the other for main functions.
And I need Proteus compatibilty of course !  Roll Eyes if PIC with some demonstration examples it would be perfect too  Cool
Simple, isn't it ?  Grin
orpheedulogis
« Reply #3 on: November 19, 2010, 09:17:37 21:17 »
And what about this:
PIC18F4523
I know: it does'nt have two SDA pins but it have 12 bits ADC (like PIC4553) and a real I2C
I searched and found a DS1374. Do you think it would be interesting I put speed pulse to this I2C and ask for value so I can deliver my PIC from speed pulse interrupts ?
orpheedulogis
« Reply #4 on: November 20, 2010, 12:03:56 00:03 »
OK, now I tried PIC18F4523 on proteus simulation but I have a problem
My software was working for PIC4553
I just changed Soft_I2C -> I2C1
I tried to pour HS+PLL but proteus failed (too much speed I suppose) so I put "HS" only
For test I have a blinking LED
This shows me software stop when I ask for I2C, in fact as soon as I have I2C start
Where could be the problem ?
in Main
  TRISA  = %00001111         ' PORT A
  TRISB  = %00011011         ' PORT B
  TRISC  = %10000100         ' PORT C
  TRISD  = %01010011         ' PORT D
  TRISE  = %00000000         ' PORT E
  PortA=%00110000 '
  PortB=%00000000
  PortC=%00100000
  PortD=%00000000
  PortE=%00000000
  OSCTUNE=0 'réglage par défaut
  UART1_Init(9600)
  CMCON = 0X07        ' Turn off all comparators.
  INTCON=0 'pas d'interruption
  ADCON0 = 0x01       ' choix canal convertisseur A/D (ici=1)
  ADCON1 = 0X00       ' Reset registre A/D 1.
  ADCON1 = %1100  ' activation AN2,AN1,AN0
  I2C1_init(100000)
  Lcd_Init()
  Lcd_Cmd(_LCD_CURSOR_OFF)
  INTCON.INT0IE = 1
  INTCON.INT0IF = 0
  INTCON3.INT1IE = 1
  INTCON3.INT1IF = 0
  INTCON3.INT1IP= 0
  INTCON.INTEDG0=1
  INTCON2.INTEDG1=1
  INTCON.GIE = 1
  BlinkKeybLed(3) ' for test
  LireEepromWord(ConvAdress)
Here the sub
Sub function LireEepromWord(dim AdresseDonnee as word) as word
dim OctetLu as byte
   I2C1_Start() '-> here it wait
   I2C1_Wr(Adresse24C512)
   I2C1_Wr(hi(AdresseDonnee))
   I2C1_Wr(lo(AdresseDonnee))
   I2C1_Start()
   I2C1_Wr(Adresse24C512 or %00000001)
   OctetLu=I2C1_Rd(1)
   result=OctetLu*256+I2C1_Rd(0)
   I2C1_Stop()
end sub
The advantage with 4523 is it seems to be approximatively compatible to 4553 ... it seems  Roll Eyes
Thanks for help
