March 07, 2026, 06:30:38 06:30
Author Topic: 0-10V ballast controller with pic18F2525 PWM  (Read 8274 times)
LeoDorant
« on: November 07, 2010, 09:39:44 21:39 »
Kindly a quick comment on the following project. I want to dim an electronic T5 ballast through PWM on a PIC18F2525. Ballast has +/- inputs and a "max 0.2 mA" label.
I've found a solution that looks something like: PWM -> low pass filter -> op amp -> output, according to Microchips AN538 http://ww1.microchip.com/downloads/en/AppNotes/00538c.pdf
I'm doing the PWM at 19.5kHz.
Now, would the attached schematics work for this purpose ? I cant get the simulation in ISIS to output anything useable. I just get the 0V/5V pulses as fast as my animation permits.
/Leo
-Given: 858
-Receive: 4451
« Reply #1 on: November 07, 2010, 11:07:28 23:07 »
Problems with your post no code.
electronic T5 ballast (there must be 1000's some are classed as dimmable)
Why no Model # or data sheet If Dimmable what type of control ballast looking for ?
The microchip app is "Using PWM to Generate Analog Output" so are you looking for a steady voltage.?
PWM 0 to 10V as per Microchip app for proteus
« Last Edit: November 08, 2010, 12:03:22 00:03 by pickit2 » Logged
LeoDorant
« Reply #2 on: November 08, 2010, 10:01:06 10:01 »
Thanks, my code is as follows. I need to produce a steady voltage between 1-10V to dim the ballast according to my "moon" position (ie. my lamp). Sort of a sunriser with gradual rise/set controlled by PWM.
The ballast is at best an EVG 2x24W T5 dimmable, with a max current rating of 0.2mA. I cant find any datasheets unfortunately.
void setmoonparam () {
   if (hrs>=uphr) {
      if (min>=upmin) {
            if (updown==0) {
            setup_ccp2(CCP_PWM);                            // Configure CCP2 to PWM on pin C1
            setup_timer_2(T2_DIV_BY_1, 255, 1);             // Tosc/((PR2+1)*4*prescale)
                                                           // 20000000/((255+1)*4*1) = 19,5kHz, 51,2us
            updown = 1;
            moonintensity = intensitet[abs(fullmoon-day)];
            set_pwm2_duty(255*moonintensity/100);
      else {
         if (updown==1) {
            setup_ccp2(CCP_OFF);
            setup_timer_2(T2_DISABLED,0,1);
         updown = 0;
         moonintensity = 0;
