April 29, 2026, 11:38:53 11:38
Author Topic: Rhinocam pluggin for rhino 4  (Read 9192 times)
cncdude
-Given: 28
« on: August 12, 2010, 12:46:12 00:46 »
RhinoCAM PRO 2.0.4.0 | 75MB
RhinoCAM is a Rhinoceros plug-in that runs completely inside of Rhino. This plug-in is a general purpose machining program targeted at the general machinist. RhinoCAM includes 2-1/2, 3, 4 & 5 axis milling and hole making operations. It comes with hundreds of post-processors and additionally a post-processor generator to create user definable post-processors.
The table below summarizes the various features found in each of the available configurations of RhinoCAM 2.0.
NOTE: RhinoCAM 2.0 is a plug-in that is completely integrated in Rhinoceros 4.0* and requires Rhinoceros 4.0 to be installed in order for it to run. It is not a standalone application. Also note that RhinoCAM 2.0 does not include Rhinoceros 4.0. It will have to be purchased separately.
*Rhinoceros 4.0 is a NURBS based 3D CAD modeler that can be used to create, edit, analyze, document, render, animate, and translate NURBS* curves, surfaces, and solids and polygon meshes. It supports the following file translators: DWG/DXF(AutoCAD 200x, 14, 13, and 12 ), IGES, SAT (ACIS), DGN, FBX, X_T (Parasolid), 3DS, LWO, STL, SLC, OBJ, AI, RIB, POV, UDO, VRML, BMP, TGA, CSV (export properties and hydrostatics), uncompressed TIFF, STEP, VDA, GHS, GTS, KML, PLY, SketchUP, SolidWorks.
For more information on Rhinoceros 4.0 go to Modeling tools for designers 2-1/2 Axis Milling
STD
Pocketing
Profiling
Facing
Engraving
V-Carving
V-Carve Roughing
Chamfering
Hole Making
Thread Milling
Re-Machining
3 Axis Milling
Horizontal Roughing
Parallel Finishing
Horizontal Finishing
Radial Machining
Spiral Machining
Plunge Roughing
Horizontal Re-roughing
Plunge Re-roughing
Projection Pocketing
3D Offset Profiling
3D Offset Pocketing
Pencil Tracing
Valley Re-Machining
Plateau Machining
Steep Area Parallel Machining
Horizontal Hill Machining
Curve Machining
Between 2 Curves Machining
Reverse Post Machining
4 Axis Milling
4 Axis Indexed Machining
4 Axis Auto Multiple Indexing
4 Axis Continuous Facing
4 Axis Continuous Pocketing
4 Axis Continuous Profiling
4 Axis Continuous Engraving
4 Axis Continuous Finishing
4 Axis Continuous Roughing
5 Axis Milling
Hole Making
Automatic Hole Selection, Sorting
Drilling
Tapping
Boring
Reverse Boring
User Defined Cycles
4 Axis Drilling
4 Axis Tapping
4 Axis Boring
4 Axis Reverse Boring
Toolpath Simulation
Toolpath Animation
Cut Material Simulation
Advanced Cut Material Simulation
Standard Mill Tools (Ball, Flat, Corner Radius, V, Taper)
Standard Drill Tools (Drill, Tap, Bore, Reverse Bore)
Form Tools
Holder Collision Detection
Toolpath Graphical Editing
Toolpath Instancing
Toolpath Arc Fitting
Customizable Post Generator
Simulate Cycles
Arc Output
Helix Output
Spiral Output
5 Axis Output (Extra Cost)
HTML Based Shop Documentation
Knowledge Base
Fixture Offset Programming
Check Surface Boundary Creation
Tool Silhouette Boundary Creation
Tool Double Contact Boundary Creation
Tool Holder Collision Boundary Creation
G-Code Editor & Analysis Tool
DNC for single port
http://hotfile.com/dl/39588989/4be5799/RhinoCAM_PRO_v2.0.4.0___.rar.
ps if anyone has rhino 4 for me as a rapidshare id appreciate it,i did have it on my old pc but can not get into it .
« Last Edit: August 12, 2010, 12:51:44 00:51 by daz » Logged
« Reply #1 on: August 12, 2010, 01:10:16 01:10 »
I haven't tried these out, but the links are good:
http://rapidshare.com/files/334980529/Rhino.4.0.SR7.2009.12.14.part1.rar
http://rapidshare.com/files/334980738/Rhino.4.0.SR7.2009.12.14.part2.rar
http://rapidshare.com/files/334982403/Rhino.4.0.SR7.2009.12.14.part3.rar
http://rapidshare.com/files/334980756/Rhino.4.0.SR7.2009.12.14.part4.rar
cncdude
-Given: 28
« Reply #2 on: August 12, 2010, 01:43:14 01:43 »
cheers ive just this minute found 3, downloaded them,gone to extract but prompted for password ???if i cant get in i,ll try those;)
cncdude
-Given: 28
« Reply #3 on: August 13, 2010, 01:22:49 13:22 »
just to add the 4 files for the above rhino 4 are an evaluation version,which will only let you save 25 times, there is a text document within the files with several serial keys but i never got an option to use them have i missed something? is it possible to unlock the evaluation package?
Amon
-Given: 65
-Receive: 50
« Reply #4 on: August 22, 2012, 12:50:40 12:50 »
RhinoCAM link is dead.
Another option?
Thank you.
