April 11, 2026, 12:22:52 12:22
Author Topic: RTD Simulator schematic/project  (Read 6846 times)
wanderingmoose
-Given: 36
« on: August 09, 2010, 04:15:03 04:15 »
I have searched the net for a digital RTD simulator schematic/project. Have not found one.
I would like to get past the tuning of a ten turn 200 ohm pot with a multimeter and then hooking it to the transmitter for testing, but not want to pay the big price of a ready made one.
Has anyone built one or have access to a schematic?
RTD is a temperature measurement device.
This is a example of a commercially built RTD simulator:Altek Model 311A Universal RTD Calibrator
wanderingmoose
"There is a theory which states that if ever anyone
 discovers exactly what the universe is for and why
it is here, it will instantly disappear and be replaced
by something even more bizarre and inexplicable."
"Some believe that this has already happened."
                 Douglas Adams
LabVIEWguru
-Given: 276
-Receive: 593
« Reply #1 on: August 09, 2010, 06:21:39 06:21 »
I used to use a resistor decade box to calibrate RTD circuits. It was a real antique (I think heathkit) good for .01 ohm. The nominal resistance was 350 ohm, I plotted the temps and did a least squares curve fit to come up with the values. Once I had the values, I just printed them out and used them to set any temperature.
I don't know the range or tolerance you are after, but I just checked Ebay and they had "decade boxes" in experimenter quality starting at 99 cents to several hundred dollars for a NIST calibrated version. I'd pay $10 just to experiment. The 1st one that came up went in 1 ohm steps. If you are just proving an idea, that's probably good enough.
« Last Edit: August 09, 2010, 06:23:43 06:23 by LabVIEWguru » Logged
