You think I am funny guy huh?
April 11, 2026, 12:23:36 12:23
Author Topic: [REQ]Rotary Encoder code  (Read 9726 times)
niktesla
-Given: 166
-Receive: 280
« on: June 29, 2010, 10:21:15 10:21 »
Anyone have any examples of C code CCS for reading encoder and presentation of value on an LCD?
niktesla
« Last Edit: June 29, 2010, 10:31:33 10:31 by niktesla » Logged
hosmis
-Given: 374
-Receive: 244
« Reply #1 on: June 29, 2010, 11:18:59 11:18 »
#use delay(clock=20000000)
#include <lcdflex.c>
int32 konum;
int1  yon,eskia,eskib,yenia,yenib;
#int_RB
void  RB_isr(void){
     yenia=input(pin_b6);
     yenib=input(pin_b7);
       yon=eskia^yenib;
     konum=konum+(2*yon)-1 ;
     eskia=yenia;
     eskib=yenib;}
void main()
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   enable_interrupts(INT_RB);
   enable_interrupts(GLOBAL);
   lcd_init();
   while(TRUE)
   lcd_gotoxy(1,1);
   printf(lcd_putc,"\KONUM(mm)=%05Ld ",konum);
   lcd_gotoxy(1,2);
-Receive: 4459
« Reply #2 on: June 29, 2010, 11:23:47 11:23 »
not in C but will give you starting point.
http://www.mcmanis.com/chuck/robotics/projects/lab-x3/quadratrak.html
niktesla
-Given: 166
-Receive: 280
« Reply #3 on: July 01, 2010, 12:41:39 00:41 »
int32 konum;
#int_RB
void  RB_isr(void){
       yon=eskia^yenib;
     eskia=yenia;
     eskib=yenib;}
void main()
   lcd_init();
   while(TRUE)
   lcd_gotoxy(1,1);
   lcd_gotoxy(1,2);
Lcdflex.c tried the file but not found, you have to send me?
thank's
hosmis
-Given: 374
-Receive: 244
« Reply #4 on: July 01, 2010, 12:56:23 00:56 »
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_D4
#define LCD_DB5   PIN_D5
#define LCD_DB6   PIN_D6
#define LCD_DB7   PIN_D7
#define LCD_E     PIN_D3
#define LCD_RS    PIN_D2
//#define LCD_RW    PIN_D1
//#define USE_LCD_RW   1
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define lcd_type 2        // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
 0xc,                    // Display on
 1,                      // Clear display
 6                       // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2));
 output_bit(LCD_DB6, !!(nibble & 4));
 output_bit(LCD_DB7, !!(nibble & 8));
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
   output_high(LCD_RS);
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
#endif
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 60 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_LCD_RW
    delay_ms(5);
    #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
   address = lcd_line_two;
else
   address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1,2);
       break;
    case '\b':
       lcd_send_byte(0,0x10);
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
#endif
/*Here's a test program for the Flex driver:
Kod:
#include <16F877.H>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
#include "flex_lcd.c"
void main()
lcd_init();  // Always call this first.
lcd_putc("\fHello World\n");
lcd_putc("Line Number 2");
while(1);
#define LCD_RS    PIN_D1
//#define LCD_RW    PIN_D2
// To prove that the driver can be used with random
// pins, I also tested it with these pins:
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_C5
#define LCD_DB7   PIN_B5
#define LCD_RS    PIN_E2
#define LCD_RW    PIN_B2
#define LCD_E     PIN_D6
// If you want only a 6-pin interface to your LCD, then
// out the following line.  Doing so will save one PIC
// pin, but at the cost of losing the ability to read from
// the LCD.  It also makes the write time a little longer
// because a static delay must be used, instead of polling
// the LCD's busy bit.  Normally a 6-pin interface is only
// used if you are running out of PIC pins, and you need
// to use as few as possible for the LCD.
//#define USE_RW_PIN   1
// These are the line addresses for most 4x20 LCDs.
#define LCD_LINE_1_ADDRESS 0x00
#define LCD_LINE_2_ADDRESS 0x40
#define LCD_LINE_3_ADDRESS 0x14
#define LCD_LINE_4_ADDRESS 0x54
// These are the line addresses for LCD's which use
// the Hitachi HD66712U controller chip.
#define LCD_LINE_2_ADDRESS 0x20
#define LCD_LINE_3_ADDRESS 0x40
#define LCD_LINE_4_ADDRESS 0x60
#define lcd_type 2   // 0=5x7, 1=5x10, 2=2 lines(or more)
int8 lcd_line;
 0x20 | (lcd_type << 2),  // Set mode: 4-bit, 2+ lines, 5x8 dots
 0xc,                     // Display on
 1,                       // Clear display
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
#ifdef USE_RW_PIN
int8 retval;
retval = 0;
output_high(LCD_E);
delay_us(1);
output_low(LCD_E);
delay_us(1);
return(retval);
#endif
#ifdef USE_RW_PIN
int8 low;
int8 high;
//output_high(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_RS);
#ifdef USE_RW_PIN
#else
delay_us(60);
#endif
if(address)
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_RW_PIN
//output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
void lcd_init(void)
int8 i;
lcd_line = 1;
output_low(LCD_RS);
#ifdef USE_RW_PIN
#endif
output_low(LCD_E);
// Some LCDs require 15 ms minimum delay after
// power-up.  Others require 30 ms.  I'm going
// to set it to 35 ms, so it should work with
// all of them.
delay_ms(35);
    delay_ms(5);
    // the hard-coded delay of 50 us, so in
    #ifndef USE_RW_PIN
    delay_ms(5);
    #endif
int8 address;
switch(y)
   case 1:
     address = LCD_LINE_1_ADDRESS;
     break;
   case 2:
     address = LCD_LINE_2_ADDRESS;
     break;
   case 3:
     address = LCD_LINE_3_ADDRESS;
     break;
   case 4:
     address = LCD_LINE_4_ADDRESS;
     break;
   default:
     break;
address += x-1;
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      lcd_line = 1;
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1, ++lcd_line);
       break;
    case '\b':
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_RW_PIN
char value;
lcd_gotoxy(x,y);
output_low(LCD_RS);
return(value);
#endif
