April 29, 2026, 12:30:42 12:30
Author Topic: Matrix led help needed  (Read 4519 times)
sureshsharma2032
« on: June 25, 2010, 11:49:54 11:49 »
I have downloaded these file the simulation is running but the leds or always off. Pls can anyone let me know why the leds are not running.
zuisti
-Given: 242
-Receive: 780
« Reply #1 on: June 25, 2010, 02:54:07 14:54 »
Hi;
These projects are "made by me" but a long ago.
Now I have tried all, they are running as well (using 7.6sp0).
However, the  Pic8ch1.DSN is running only from Proton IDE Proteus plugin while the
bas source is compiled. Sorry. The other (Pic8ch1bas1.DSN) is running stand-alone
in Proteus.
But ... these project are "obsolete" yet (for ex. only char by char scrolling, small buffer ...)
Look at my newer project here:
http://www.sonsivri.com/forum/index.php?topic=7978.0
Have a nice day
zuisti
sureshsharma2032
« Reply #2 on: June 25, 2010, 03:22:07 15:22 »
Sir, I have downloaded the newer file you have shown but the problem is same, the simulation is running but why aren't the leds working it's always off. I am using proteus v7.7 SP2.
zuisti
-Given: 242
-Receive: 780
« Reply #3 on: June 25, 2010, 04:46:35 16:46 »
proteus v7.7 SP2.
All (also the new) are tried with 7.7sp2 portable (on XP sp2 english) and ... success.
Examine your Proteus install.
zuisti
« Last Edit: June 25, 2010, 04:56:15 16:56 by zuisti » Logged
sureshsharma2032
« Reply #4 on: June 25, 2010, 07:00:10 19:00 »
Now, I got it working. The problem was I had set paths for extra Library & Models in the set paths menu . I had downloaded the samples, models & library from here. I had to remove the extra paths to get it work. Pls. may you help to what would had happened.
Sir, I have a request to you. I am new to microcontrollers & PIC & I want to get to the fullest of microcontrollers & PIC knowledge. Pls can you guide from where to start as a begineer what book would you recommend or software that can be found on the site to download.
