April 29, 2026, 07:14:51 07:14
Author Topic: [req]can anyone tell how to use CD Drive to play songs without computer  (Read 6239 times)
mastertushar
-Given: 19
« on: June 07, 2010, 08:21:38 08:21 »
once upon i got on internet that how to use a CD/DVD drive to play songs from cd without using computer. but now i lost it.. has anyone idea about it ... plz tell thanx in advance.
dennis78
-Given: 284
-Receive: 155
« Reply #1 on: June 07, 2010, 11:25:47 11:25 »
I don't know what information you need. I guess you need some project with MCU for control of CD-ROM.
1.If you want just simple player for CD tracks, project is very simple. You need little MCU and several external components.In this case decoding and D/A conversion will be done inside same CD-ROM. You will only do simple control of number track, play/pause/stop/eject.
2. If you need mp3 player you must use mp3 decoder chip or most complicate variant with software decoding (in case of software decoding mp3 you must use powerful controller like ARM...).
If you haven't enough experience the best way is simple copy some project from net. You have many project of this type. Just search like: control cdrom atapi avr pic... and you will find 1000 solutions.
Here is one:
http://www.8051projects.info/blogs/post/A-Simple-8051-based-ATAPI-CDROM-audio-controller.aspx
« Last Edit: June 07, 2010, 11:44:19 11:44 by dennis78 » Logged
-Given: 239
-Receive: 1058
« Reply #2 on: June 07, 2010, 12:52:27 12:52 »
You should look at the back of you CD-ROM player. It may have a analog outout like shown in the picture. If you connect the power. The CR-ROM may start autoplay then you insert a music CD. The analog output from the CD-ROM must be connected to some sort of amplifier. it can NOT be used to drive speakers directly[
-Given: 239
-Receive: 1058
« Reply #3 on: June 07, 2010, 05:22:01 17:22 »
I did a search on the web, and found some Youtube videos showing how to do this. No of them do mention any need for shorting pins on the IDE. So you should at least give it try.
Good luck
glenndr_15
-Given: 20
-Receive: 72
« Reply #4 on: June 07, 2010, 06:01:57 18:01 »
Greetings!
Here is a link where you can find some projects on audio player using PIC16f877 and cd rom drive.
http://www.sonsivri.com/forum/index.php?topic=13957.0
Best regards,
glenndr_15
mastertushar
-Given: 19
« Reply #5 on: June 08, 2010, 06:06:53 06:06 »
Good luck
ofcourse i'll try. Bro.
zuisti
-Given: 242
-Receive: 780
« Reply #6 on: June 08, 2010, 07:58:17 07:58 »
Hi;
A link (Google : - ) : "Add-a-playskip-button-to-your-standalone-CD-ROM"
http://www.instructables.com/id/Add-a-playskip-button-to-your-standalone-CD-ROM-D/
"user guide" from it's step4:
" Now to see if your drive works insert a CD and don your headphones. press PLAY/SKIP button
once to start playing. press again to Skip to next track. Press EJECT to stop and press again
to eject the disk (kinda like an old tape player..."
Cheers
zuisti
majimbu
« Reply #7 on: June 15, 2010, 11:47:17 11:47 »
hello!
some cd-rom dont have play/skip button and only have eject button.
is it possible to use this kind as stand alone cd-player?...
-Receive: 4460
« Reply #8 on: June 15, 2010, 12:31:55 12:31 »
hello!
Why don't you read the topic This is from the post before yours.
from first page
introAdd a play/skip button to your standalone CD-ROM Drive
If you want to make a CD player from an old CD-ROM drive (view here) but the drive you have doesn't have a PLAY/SKIP button on the front.....Dont dispair, you can add one to most Cd drives
