April 29, 2026, 07:15:01 07:15
Author Topic: Error "door open" on HP 2600N Printer  (Read 4818 times)
leptro
-Given: 658
-Receive: 26
« on: May 11, 2010, 06:28:32 18:28 »
Hello,all friends from sonsivri. just a hint for you.
I use at home this color printer for printing my artwork pcb, and suddenly i get this error message.
I have opened the rear metal cover panel (9 screws) and disconnect and reconnect all cables from the cpu board ( flat cable and normal cable).
And maybe i'm a lucky guy, but this error has disappear.
I hope this will be usefull for you, because in my case,i was not able to find any hint from internet.
An other hint, if one of your color toner is empty and you want to override this message :
from main menu, go to system configuration,printing quality, select ignore empty toner supply.
Regards.
« Last Edit: May 11, 2010, 06:31:59 18:31 by leptro » Logged
