April 20, 2026, 08:46:51 20:46
Author Topic: CAMWorks 2010 SP0.0 (Win32 & Win64) for SolidWorks 2009-2010  (Read 7581 times)
« on: May 07, 2010, 08:02:52 08:02 »
CAMWorks 2010 SP0.0 (Win32 & Win64) for SolidWorks 2009-2010 | 457 MB
CAM (Computer Aided Manufacturing) Works - a module for creating control programs for CNC machines. Programming of milling, turning, turning, milling and wire EDM module means CAMWorks.
Year: 2010
Version: 2010 SP0.0
Developer: Geometric Technologies, Inc.
Platform: Windows 32bit & 64bit
Compatibility with Vista: complete
System requirements:
SolidWorks Version 2009, 2010
Operating System MS Windows XP / Vista, Server 2003 - 32 & 64bit
Graphics 1024x768 resolution with minimum 32768 colors
Disk Space 10GB free
Memory 1GB + RAM (2GB recommended)
Medicine: Yes
* Module CAMWorks allows you to create programs milling, turning, turning, milling and wire EDM. The following types of machines: milling with simultaneous control of two-> five axes;
* Turning single and duplex, with one or two slides, with a programmable servo-mechanism;
* Turning and Milling single and duplex, with one or two slides, with a programmable servo-mechanism, with simultaneous control of two-> five axes
Treatment is carried out directly in SolidWorks and directly on the model of SolidWorks. The results of the programmer are stored in the same model parts or assemblies SolidWorks. This provides full associativity of the model and the tool path that leads to the automatic renewal of all the trajectories of the tool during the model changes.
When you add in the SolidWorks model of any process data, such as the designation of roughness, base, tolerances of form and position of surfaces, tolerances on dimensions, engineer-programmer always has immediate access to them, which facilitates the selection scheme based on the machine parts and selection of required provide a given quality of parts of the tool and cutting conditions.
The part can be easily adapted to the needs of processing by, for example, avoiding redundancies in terms of processing elements of geometry, or by converting the size of the executive model in the middle of the tolerance field. While working with the SolidWorks assembly can perform a joint processing of multiple parts, program processing a series of items, or just completely simulate all the real situation on the machine table - all of snap-in, logging of any complexity, and so on - for the most complete account the realities of treatment at the earliest stages a program
Homepage: http://anonymz.com/?http://www.camworks.com/
Download:
http://hotfile.com/dl/41300900/66c7ec2/CAMWorks.2010.SP0.0.part1.rar.html
http://hotfile.com/dl/41300927/8b4fda0/CAMWorks.2010.SP0.0.part2.rar.html
http://hotfile.com/dl/41300966/fbbf5ae/CAMWorks.2010.SP0.0.part3.rar.html
http://hotfile.com/dl/41300998/e420bf7/CAMWorks.2010.SP0.0.part4.rar.html
http://hotfile.com/dl/41301029/6d7c61a/CAMWorks.2010.SP0.0.part5.rar.html
jesse
-Receive: 101
« Reply #1 on: May 10, 2010, 07:00:18 19:00 »
     Update for Camworks
    http://www.filefactory.com/file/b19aee5/n/CW_2010_sp0.1.rar
    Saludos
jesse
-Receive: 101
« Reply #2 on: June 20, 2010, 06:07:26 18:07 »
      Latest Update for Camworks, SP1.0:
      http://www.filefactory.com/file/b2278b5/n/camworks2k10sp1.rar
      Saludos
