January 25, 2026, 12:30:40 12:30
Author Topic: mikroC compiler + winavr  (Read 10217 times)
powermosfet
« on: May 01, 2010, 11:26:14 11:26 »
hello,
I will like to know if its possible to use winavr libraries with mikroC compiler if yes than how do I include stuff.
for example #include <avr/io.h> or #include <util/delay.h>
thankyou.
sam_des
-Given: 138
-Receive: 161
« Reply #1 on: May 01, 2010, 06:32:48 18:32 »
Most certainly NOT Embarrassed
mikroC & WinAVR have different formats for their binary(compiled but not linked) data. While WinAVR uses elf mikroC uses it's own proprietary format. Also as far as I know mikroC does NOT have seperate linker/librarian. It has only two executables - preprocessor & (compiler+linker+librarian).
So you can't use winavr's libs directly. You can have source code for winavr's libs & port them to mikroC, but remember these libs make full use of preprocessor & other ANSI & gcc specific exetensions, mikroC doesn't even claim to be ANSI compliant. And winavr's libs are mostly GPLed.
regards,
sam_des
powermosfet
« Reply #2 on: May 03, 2010, 09:29:08 21:29 »
it's kinda sucks using avr studio with its boring interface.
thank you for the input.
« Reply #3 on: May 03, 2010, 11:10:50 23:10 »
I think you can use codeblocks, use ultraedit or even UEStudio. They all work excellent indeed. I use them to write code, program interface too. It's easy to use them, especially codeblocks.
Thiru09
-Given: 410
-Receive: 1188
« Reply #4 on: May 04, 2010, 11:45:05 11:45 »
If that is the only problem, try to use Eclipse with WinAVR.
I am sure that Eclipse interface is marvelous.
For more details, please visit the following websites.
Step by step configuration:
http://winavr.scienceprog.com/other-valuable-tools/using-eclipse-as-ide-for-winavr-compiler.html
The AVR Eclipse Plugin:
http://avr-eclipse.sourceforge.net/wiki/index.php/The_AVR_Eclipse_Plugin
And finally, Eclipse+CDT:
http://www.eclipse.org/cdt/
Thiru
sam_des
-Given: 138
-Receive: 161
« Reply #5 on: May 04, 2010, 03:20:44 15:20 »
Ya, Eclipse is good. But I find that too heavy for my work. Besides running damn slow, it eats my hard-disk and I am not into Java app development and certainly not easy to setup.
I feel much at home using Code::Blocks. Nearly does everything I wish for, cross-dev, pc dev. Has all the features I care for in an IDE & that too with small footprint & good speed.
And When I feel really wacky, I use good old Vim  Grin
sam_des
« Reply #6 on: May 04, 2010, 07:46:08 19:46 »
This eclipse winavr project has not been updated for a longtime..
powermosfet
« Reply #7 on: May 04, 2010, 08:26:18 20:26 »
hi,
eclipse is a great application which I have been and using for a quite long time now. I have done many of my school projects using eclipse without any problems. I do recommend eclipse.
about ultraedit & UEStudio looks nice but how do i compile the code? I guess it should be outside of ultraedit and or UEStudio.
codeblocks + winavr  guide
Make sure to install WinAVR first.
Download and install Code::Blocks next
Create a new AVR GCC project
Go to Tools->Compiler and Debugger Settings
Change "Selected Compiler" to "GNU AVR GCC Compiler"
Alter the "Compiler's installation directory" to the WinAVR directory (should be on the C: drive root)
Go to Project -> Build Options
Under Compiler Flags->Categories->AVR CPU architecture specific Select your uC as a flag
Could save all of this as a user project template
« Last Edit: May 04, 2010, 09:40:50 21:40 by powermosfet » Logged
-Given: 857
-Receive: 4447
« Reply #8 on: May 04, 2010, 09:02:05 21:02 »
Most if not all Compilers allow you to use any Text editor. UltraEdit as most profile Templates too.
« Reply #9 on: May 04, 2010, 10:19:01 22:19 »
Here you go, this is from UEStudio..
« Last Edit: May 04, 2010, 10:21:29 22:21 by metal » Logged
powermosfet
« Reply #10 on: May 05, 2010, 07:03:28 07:03 »
alright Im convinced. It absolutely deserves a try
