SED1335 driver (with anti-flicker) - Sonsivri
May 12, 2026, 08:14:49 20:14
Author Topic: SED1335 driver (with anti-flicker)  (Read 7517 times)
dezso
-Given: 34
-Receive: 137
« on: April 30, 2010, 05:17:54 05:17 »
This is what I'm after for, the sed1335.c found in the CCS driver folder works but the screen segment flicker on write.
Not super noticeable but like to get rid of it.
If any of you have some experience driving this chip please share your code.
dezso
-Given: 34
-Receive: 137
« Reply #1 on: May 04, 2010, 09:15:49 21:15 »
No one Huh
ok
Here is what I got so far.
According to Epson's datashets if we write during memory read the display flicker can occur.
This is the original write routine created by CCS, no busy check.
// Purpose:    Write a byte of data
// Inputs:     The byte of data to write
void glcd_sendByte(byte data)
   output_d((data));
   output_low(GLCD_CS);
   delay_cycles(1);
   output_low(GLCD_WR);
   delay_cycles(2);
   output_high(GLCD_WR);
   output_high(GLCD_CS);
my version with busy check, whoever this will slow done the display significantly, I don't think I can get more than 2fps.
   int status;
   output_low(GLCD_A0);
   output_low(GLCD_RD);
   delay_us(1);
   status = input_d();
   while (bit_test(status,6) != 1)
   status = input_d();
   while (bit_test(status,6) == 1)
   status = input_d();
   output_high(GLCD_RD);
   output_d((data));
any suggestion....
