night_mare
-Given: 40
« on: April 05, 2010, 07:23:02 07:23 » |
My laptop Panasonic Model:CF-Y2 show me this message when I try to set up XP 2005 boot from CD. What is the reason behind this?? Please give a solution.............( i m bit scared about my laptop)
glicos
-Given: 37
« Reply #1 on: April 05, 2010, 08:39:25 08:39 » |
What's the previous OS of your laptop? Error indicates a corrupted partition or the partition info of your laptop have problems. Maybe, your using different OS previously...Best thing to do is re-partition your hardisk using the old way (DOS mode). You can download utility to make bootdisk here: http://www.bootdisk.com/
« Last Edit: April 05, 2010, 08:44:21 08:44 by glicos »
-Receive: 4460
« Reply #2 on: April 05, 2010, 01:20:50 13:20 » |
Concerning the partmgr.sys blue screen error, sounds like MBR is bad. The XP installation disk gives you the option to format in NTFS, FAT, and both formats in a "quick" mode. try NTFS (quick). I would say its a format of hard drive problem. You have loads of options to fix this problem, info is needed as to do you have a usb/built in Floppy drive, or a bootable pen drive.
night_mare
-Given: 40
« Reply #3 on: April 06, 2010, 06:51:46 06:51 » |
I ve already tried all format option (fat, fat quick, ntfs, ntfs quick) but result is same. previously Xp was loaded. plz help me.......
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #4 on: April 06, 2010, 09:42:12 09:42 » |
I'd grab a copy of XP Pro SP3 and see if it got me around the problems. This one is quite well liked: http://thepiratebay.org/torrent/5199210/WINDOWS_XP_PRO_32-BIT_SP3_ISO_ACTIVATED_GENUINE
microkid
-Given: 46
-Receive: 23
« Reply #5 on: April 06, 2010, 12:44:35 12:44 » |
Try disabling native sata in cmos setup. If the os does not support sata drives, you cant install older version of windows.
MickroKid
Never Never Never giveup
-Receive: 4460
« Reply #6 on: April 06, 2010, 01:00:20 13:00 » |
You could not have tried all format options, but ten to one, it's the MBR, I would format drive with say Dos6.2 and Fdisk /MBR two or three times. you will be limited to the size of dos, but all you want to do is fix the MBR. There are other options, but you need to tell us, Have you a bootable floppy, pen drive, or if you have a usb caddy, you could put the hd drive in.
night_mare
-Given: 40
« Reply #7 on: April 06, 2010, 07:48:05 19:48 » |
pickit please more details........
-Receive: 4460
« Reply #8 on: April 06, 2010, 08:27:44 20:27 » |
The MBR or master boot record it tell the OS, about boot up and the partition table, it has hidden sectors too. Microshaft and others used to hide licence info here too. So if you need to replace the MBR, easy way is to use msdos Fdisk/MBR command (for a long time this was undocumented), sometimes you need to run command FDISK/MBR 2 to 3 times, to clear a sticky or messed up MBR.
night_mare
-Given: 40
« Reply #9 on: April 07, 2010, 03:19:02 15:19 » |
pickit why i erase master boot record? is it concerned with XP set up?
