April 29, 2026, 11:50:11 11:50
Author Topic: how networking can be done in two PC without using hub  (Read 5067 times)
night_mare
-Given: 40
« on: April 04, 2010, 06:18:12 18:18 »
hi i have two PC laptop and desktop. I want to connect these PC using only network wire (two pc connected straight through two nic card).Also I want to set  up XP using this connection.Is it possible?
-Receive: 4460
« Reply #1 on: April 04, 2010, 06:29:43 18:29 »
yes you only need a x-over cable, google or microsoft has help files on how to do this.
You only need 2 pair or 4 wires to make connection.
you could cut a straight through cable and swap over the leads.
quick google show this.
http://en.kioskea.net/forum/affich-10077-how-to-connect-2-systems-using-lan
« Last Edit: April 04, 2010, 06:33:12 18:33 by pickit2 » Logged
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #2 on: April 05, 2010, 01:56:05 01:56 »
Follow this chart:
MGLSOFT
-Given: 32
-Receive: 73
« Reply #3 on: April 05, 2010, 03:49:55 03:49 »
Ja..Ja..!!!
Is a good Idea !!! Grin Grin Grin
sakugava
Translator
-Given: 292
-Receive: 188
« Reply #4 on: May 20, 2010, 09:58:36 21:58 »
If you have at least on gigabit adapter, you can use a straight trough cable
glenndr_15
-Given: 20
-Receive: 72
« Reply #5 on: May 24, 2010, 11:36:24 11:36 »
Greetings!
here is a link on how to set up a network on 2 computer without the use of router or a hub,
http://www.networking.windowsreinstall.com/directconnectionnetwork/index.htm
Best regards,
glenndr_15
night_mare
-Given: 40
« Reply #6 on: July 02, 2010, 07:38:39 19:38 »
glennder I ve set up IP in two pc's described in the link u provide. After that what shoud I do Huh Huh Huh Huh
thecic
« Reply #7 on: July 03, 2010, 11:47:46 11:47 »
Then you go to the folder and share it so it becomes visible on your little network.
First a small preparation.. doubble click "My Computer" -> go to menu "Tools" -> Folder alternatives (not sure what's the real name in English because my Win XP is in another language, anyway..) -> pop-up window appears, go to "viewing" (again not sure the exact name in Win XP Eng.) -> files and folders ->un-tick "use simplified filesharing.."
Next step..
Right click on the folder you want to share on the network -> properties -> pop-up window appears, go to "share" and tick the radio button -> click OK...
