January 25, 2026, 06:14:13 06:14
Author Topic: Timing alarm ckt using at89c2051...interfacing it with lan  (Read 8054 times)
sinner
« on: March 22, 2010, 04:36:36 16:36 »
hi everyone...my friend give me a task to install a an alarm circuit i his little industry.....he gave me instructions that a circuit should alarm after every 30 minutes,and it must only stops when any worker press the button,and when button is pressed the timer must restart ...every time a button is pressed. ckt should acknowledge the computer (data logging) the time button is pressed..
so i thought to use at89c2051 for this purpose i have made the ckt prototype....but still some problems are there, i have to design a driver ckt to on the alarm.and i dont know how to do data logging on pc...i saw ic ENC28J60 ethernetcontroller...but dont know how to program and wht its range to carry data signal....im not using serial communication bcoz it has distance limit too short......can anyone help me in programming this micro controller and ethernet controller...
rentau
-Receive: 15
« Reply #1 on: March 23, 2010, 01:50:08 01:50 »
at89c2051? 2k flash with 128bytes of RAM. you can do something like driving relay, some buzzer and a SIMPLE RS232 communication with easy to use wireless communication to your PC. or wire it XD
« Last Edit: March 23, 2010, 01:52:14 01:52 by rentau » Logged
everything has its beginning ,not all has its end~
sinner
« Reply #2 on: March 24, 2010, 06:06:58 18:06 »
difficulty facing in 89c2051 based alarm....ckt is intended to alarm after every 30 minutes..and after a key is pressed ,alarm should be stop,,the ckt should communicate serially via rs232....
sam_des
-Given: 138
-Receive: 161
« Reply #3 on: March 24, 2010, 07:21:59 19:21 »
Hi sinner,
You forgot to tell us about problem you are facing Tongue
It will be easier to help you if ask questions correctly.
I just looked (not very carefully Lips sealed), & it seems to have few problems. Is this your first program ?
I suggest that you handle one task at a time. Just do alram logic first & then worry about serial interface.
And use C if you can. There are many excellent compilers for 8051, some are even free like sdcc.
BTW, don't start new topic unnecessarily. Continue with old topic if subject is same.
reagrds,
sam_des
sinner
« Reply #4 on: March 25, 2010, 08:50:16 20:50 »
above was the circuit i designed but it didnt run according to program....so modify my prog for other micro controller trainer i have....the program runs fine ....now the modifications i want in my hardware is seven segment display of timer and it wud be better if timer can be set by user inputs through switches... can u guide me what modifications i must do in my circuit..
ORG 00H
MOV SP,#60
MOV TMOD,#21H ;TIMER 1 MODE 2, TIMER 0 MODE 1
MOV TH1,#-3 ;9600 BAUD RATE
MOV SCON,#50H ; SERIAL MODE SPECIFIER
PROGR: MOV P1,#00H
MOV P3,#00H
ACALL DELAY
CANB: MOV TMOD,#01H
SETB P1.7 ;BUZZER INDICATOR OFF
SETB P1.4 ;ATTENDANCE INDICATOR OFF
SETB P1.1 ;SYSTEM BUSY INDICATOR OFF
CLR P1.3 ;RELAY OFF
SETB P1.0 ;BUZZER ON
ACALL DELAY
CLR P1.0 ;BUZER OFF
REPEAT: CLR P1.1 ;SYSYTEM BUSY ON
ACALL DELAY30M
SETB P1.1 ;SYSTEM BUSY LED OFF
SETB P1.3 ;RELAY ON
CLR P1.7 ;BUZZER INDIACTOR ON
SETB P1.2 ;MAKE P1.2 INPUT PORT
SWITCH: JNB P1.2,SWITCH
CLR P1.0 ; BUZZER OFF
CLR P1.3 ; RELAY OF
SETB P1.7; BUZZER INDICATOR OFF
SERIAL: SETB TR1
MOV DPTR,#MYDATA
SER_1: CLR A
MOVC A,@A+DPTR
JZ REPEAT
ACALL TRANSMIT
INC DPTR
SJMP SER_1
TRANSMIT:
MOV SBUF,A
T_1: JNB TI,T_1
CLR TI
RET
DELAY: MOV R4,#100
DL1: MOV R5,#200
DL2: MOV R6,#200
DL3: DJNZ R6,DL3
DJNZ R5,DL2
DJNZ R4,DL1
RET
DELAY30M:
MAIN: MOV R1,#9
MAIN1: MOV R2,#200
MAIN2: ACALL TIMER
DJNZ R2,MAIN2
DJNZ R1,MAIN1
RET
TIMER:
BACK: MOV TH0,#4BH ; FOR 50MS
MOV TL0,#0FDH
SETB TR0
TIM: JNB TF0,TIM
CLR TR0
CLR TF0
RET
MTDATA : DB 'MACHINE ATTENDED',0
END
sam_des
-Given: 138
-Receive: 161
« Reply #5 on: March 25, 2010, 09:39:43 21:39 »
You still did NOT tell us what problem you are actually facing  Angry
Is your program running at all ? or running just once ? or doing alarm but not serial output ? or vice versa ?
You don't even bother to mention what your crystal freq is in either your ckt or your code  Angry
Or do you expect others to write that program down for you ? Angry
If you are testing your code on trainer, note that 8051 trainers usually have ROM monitor, which in turn downloads & runs your program from RAM & also provide additional functions to you, like keypad, 7-segment display.
It's first & foremost rule of software developement to simplify problem at hand & here you are increasing it now by adding 7-segment & switches to set time while your program isn't functioning in the first place without it. Tongue
As I told you in previous post, divide your task & test them independently and once you got them working integrating them together is an easy task. Run each part in simulator independently, step through your code & see if it's working. Try changing few inputs such as clock, delay desired etc & see how this affects your code. Does it holds or breaks down ? This is how reusable blocks of code are written. Now burn your code into actual CPU, use few dummy/debug outputs to checkpoint your code. It is nice to have ICE like tools, but surely we can do without them. Once you're satisfied, go onto next task.
There is no main-line loop in your program. Since you want your code to run indefinitely until power is removed, your code should have a infinite loop. That's why asked you if this your first program or not !!!
Secondly, it seems you're pretty poor coder. Your comments aren't telling us anything other than what each statement line does. Purpose of commenting the code is not just telling 'what' but also 'how' & 'why'. Develop this skill early in your career or you will be always figihting with your code & collegues later. Remember there will be v2.0, and you will definitely wish to use code from v1.0.
Also, using assembly over HLL, require even more care, since it is now even less clear what code does just by looking at code.
There is nothing wrong with doing mistakes but unwillingness learn & to hardwork certainly is Lips sealed
regards,
sam_des
« Last Edit: March 25, 2010, 09:44:38 21:44 by sam_des » Logged
DreamCat
-Given: 223
-Receive: 116
« Reply #6 on: April 11, 2010, 03:11:19 15:11 »
2051 with LAN? maybe it is a little difficult, though you use 28j60.
I think your means that he need a circuit, general alarm once every 30 minutes. when time is up, wait worker press the button to restart the timer count, and send data(or message) to computer?
oh sorry , I just saw the image you post.
you only want (or need) to extend distance between the computer and your device.
if distance less than 1000m, why not try rs485?
it is very simple and low cost.
