April 12, 2026, 02:27:40 02:27
Author Topic: how to connect db2 with php using wamp server  (Read 9074 times)
leyla5235
« on: March 05, 2010, 07:15:48 19:15 »
i want to connect db2 and i am using wamp server 2.0i. I add "extension=php_ibm_db2.dll" line to php.ini file and i copied the dll file to php\ext directory, but it could not be founded. How can I solve that problem?
Hamdi
« Reply #1 on: March 09, 2010, 03:17:05 15:17 »
Did you already installed an IBM DB2 Universal Database client on the same computer on which you are running PHP??
Try also to:
  • Install DB2 with extended operating system security.
  • Add the PHP binary path to the PATH system environment variable (default C:\php\).
  • Create another system environment variable equal to the path where the PHP.INI file is located (eg: PHPRC = C:\php\).
  • Add the IUSR_COMPUTERNAME to the DB2USERS group.
leyla5235
« Reply #2 on: March 13, 2010, 08:46:33 20:46 »
I solved the problem. I installed Wamp Server 2.0f instead of 2.0i.
