April 11, 2026, 08:56:43 20:56
Author Topic: MikroPascal PRO for AVR v2.10  (Read 7236 times)
nidhisahu
-Given: 8
-Receive: 5231
Because Knowledge Should Be Free for ALL
« on: February 12, 2010, 07:10:23 19:10 »
MikroPascal PRO for AVR v2.10 | 13.42 MB
MikroPascal PRO for AVR - a powerful tool for programming AVR microcontrollers in the language Pascal. It is designed to allow the programmer to the least labor-intensive solutions to create applications for embedded systems.
MikroPascal ensure a successful combination of advanced programming environment (IDE), the appropriate compiler, broad set of libraries for the hardware, comprehensive documentation and a large number of ready-to-use examples.
Features
MikroPascal to quickly develop and implement complex applications:
- Source code is entered using the built-in editor source code (using the code and parameters, the content backlit avtokorretsiey, code templates, etc ...).
- Use the attached libraries MikroPascal significantly increases the speed of development. It supports most of microcontrollers Atmel AVR.
- Explore the code (Code Explorer) allows for the rapid control of the program structure, variables and functions of the project.
- After treatment are otkommentirovanny and readable file in assembly and standard HEX file suitable for use by all programmers.
- Built-in debugger allows you to check the progress and execution of logic programs.
- After compiling the statistics of the total available memory, an assembler listing, a tree of function calls, etc. ...
- Provided a sufficient number of examples that can be expanded and used as components of development projects. If necessary, you can copy them on the whole, to ensure they are included in the compiler.
Currently MikroPascal PRO for AVR includes the following libraries and examples:
- ADC Library;
- CANSPI library;
- Compact Flash Library;
- EEPROM Library;
- Flash memory library;
- Graphic LCD Library;
- Keyboard Library;
- LCD Library;
- Manchester Code Library;
- Multi Media Card Library;
- OneWire library;
- Port Expander Library;
- PS / 2 Library;
- PWM library;
- PWM 16-bit library;
- RS-485 library;
- I2C Library;
- SPI Library;
- Software UART Library;
- Sound Library;
- SPI Library;
- SPI Ethernet Library;
- SPI Graphic LCD Library;
- SPI LCD Library;
- SPI LCD8 library;
- SPI T6963C Graphic LCD Library;
- T6963C Graphic LCD Library;
- TWI library;
- UART Library;
- USB library.
DOWNLOAD:
http://hotfile.com/dl/26863362/ca89257/mikroPascal_PRO_for_AVR_v.2.10.rar.html
MIRROR:
http://rapidshare.com/files/344831061/mikroPascal_PRO_for_AVR_v.2.10.rar.html
Vlsi@IIT
