April 29, 2026, 10:31:05 10:31
Author Topic: i neeed equivalent component ............  (Read 4555 times)
satya
« on: February 12, 2010, 03:56:54 03:56 »
hi
i am working on smps power supply
TL431 shunt regulator working up to 37Vdc but i need a shunt voltage regulator working 75Vdc
please give the any equivalent part number.........
« Reply #1 on: February 12, 2010, 04:14:22 04:14 »
I hope you've done the math Vdrop*I - your power dissipation just doubled....
Check out Supertex
borberk
-Given: 309
-Receive: 598
« Reply #2 on: February 12, 2010, 11:07:14 11:07 »
Use this:
tAhm1D
-Given: 103
-Receive: 180
« Reply #3 on: February 12, 2010, 04:33:09 16:33 »
satya,
You can do it with zener and transistor. For variable ref.,you can add a pot.
PilotPTK
-Receive: 23
« Reply #4 on: February 13, 2010, 05:15:43 05:15 »
You can also add a big 40ish V Zeener before the shunt regulator.  It will eat the 40 Volts and show only 35 to the Shunt regulator.
As solutions mentioned, make sure you have a part that can dissipate 40V * I = Watts.  Running the Shunt Regulator near it's limits also requires watching the VDrop * I for the regulator.
You may want to absorb even more in a zeener if the voltage in is relatively stable..
For example
75V -> 70V Zeener -> Shunt Regulator -> 12V
That way, you can use a big fat zeener, show only 15V to the Shunt Regulator and only have to drop 3V * I in the shunt.
PPtk
satya
« Reply #5 on: February 13, 2010, 05:34:13 05:34 »
hi
Thank you
but i need 75Vshunt regulator ( only single component )
i can not use any equivalent circuit.  my pcb  is very small no space available for extra components.
satya
PilotPTK
-Receive: 23
« Reply #6 on: February 13, 2010, 06:01:17 06:01 »
Without additional components, I don't think you're going to get what you need.  The highest shunt regulator that I know of takes a max of 42V IN.
What is your actual VIN and VOUT requirement?  Depending on the drop, something like a floating LM317 might work.
PPtk
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #7 on: February 13, 2010, 06:32:05 06:32 »
Perhaps you could use a TL783.  Good to 150V input.  Pretty much a LM317 on steroids.
http://focus.ti.com/lit/ds/symlink/tl783.pdf
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-20687-5-ND
A couple bucks US each.
