March 15, 2026, 07:25:25 19:25
Author Topic: linistepper V2 step motor control unit  (Read 11412 times)
sphinx
Online Online
-Given: 682
-Receive: 367
« on: February 07, 2010, 08:01:56 08:01 »
after some search on net for some good schematics that are modifiable i found lots of circuits and designs i found linistepper a nice design thats open source and has a idea behind it like simple components and deisgned for more than it handles, read more about it here http://www.piclist.com/techref/io/stepper/linistep/index.htm.
so i got the schematics and designed a single layer pcb with a couple of vias and a compiled hex file from their source, i did some small modification to schematics like using a crystal insted of resonator and some other small mods.
i tested the schematic in proteus so so far it worked nicely, i dont have my electronics hardware here with me so cant test it real life, will do later.
so i wanted to share this with you all i include even proteus files too for testing, i cant promise i made it without any bugs though i hope not but but but i am only human. i almost forgot in proteus i made a "linistepper sim" that i added its for simulation and testing with a stepper motor to see if it all worked
/regards
p.s. i changed  file and added assembler code as well i am not sure if source needs to be changed to work with a crystal instead of resonator, so change in the code and compile a new hex file.
« Last Edit: February 07, 2010, 08:16:18 08:16 by sphinx » Logged
-Given: 405
-Receive: 545
« Reply #1 on: February 07, 2010, 03:23:46 15:23 »
Come on you guy's at least thank the man if your going to download his file  Angry
lightt
-Given: 8
-Receive: 14
« Reply #2 on: May 01, 2010, 07:52:33 07:52 »
I am looking for simple, cheap and effective driver. Linistepper is good choice and has many advantages. But I have some questions in my mind.
1- For linistepper v2, I didn't find any new firmware (hex file) including your files. All codes are v1. But I know that some changes made in v2 for example enable pin functionality completely different. May be I am wrong but, I think version changes not limited to hardware changes.
2- Very personalized question but I want to use TIP152 transistors against TIP122. I checked the datasheets of products there is only one minor difference between products except voltage and current ratings. This difference is Vbe voltage of transistors. TIP122 has 5 V Vbe but TIP152 has 8V Vbe. Is it possiple to use TIP152 in this circuit?
DreamCat
-Given: 223
-Receive: 116
« Reply #3 on: May 02, 2010, 12:18:50 12:18 »
yes, you can use 152 replace 122.
I read Linistepper's webpage , it is a opensource project. you can download the source code and compile youself.
I'm very interesting the "magic" modes...
sphinx
Online Online
-Given: 682
-Receive: 367
« Reply #4 on: May 02, 2010, 04:55:59 16:55 »
well the hardware is ver2 but i havnt seen any new versions of the software, i mean its open source make any changes to the code and make your own hex file, here is everything you need to know http://www.piclist.org/techref/io/stepper/linistep/index.htm
lightt
-Given: 8
-Receive: 14
« Reply #5 on: May 07, 2010, 06:44:42 06:44 »
thanks for replies, unfortunately due to lack of ASM knowledge I cant change the code. I am going to get help with my friends.
sphinx
Online Online
-Given: 682
-Receive: 367
« Reply #6 on: May 07, 2010, 03:58:25 15:58 »
i just want to make it clear the schematics i used in my package is v2, i think compared to v1 it has some changes to it. i first thought i would like to make it with 16c84 since i have a bunch of those. but the i thought it would be better to go with the newer and updated schematics. i am just curious what is it about the code you wanna change ?
leaveme
-Given: 38
-Receive: 15
« Reply #7 on: October 16, 2010, 02:44:07 14:44 »
Hi sphinx,
Is there any difference in stepping sequence (from PIC) for Unipolar & Bipolar stepper?
I mean, is the stepping sequence is same for both stepper?
sphinx
Online Online
-Given: 682
-Receive: 367
« Reply #8 on: October 16, 2010, 05:31:19 17:31 »
i am not sure was going to have a peek at that. looked at bipolar but i need some more time to figure that
out. since i am not that familiar with either of them i need to read on how these two types differ in their mode of working..
i got my pickit 3 guess i need to order a cuple of pic's sine i got some stepper motors in my "good to have stuff box" and at least run them on the table first,
i got back from US after a 2 year stay so lots of my things are in boxes, and on top of that i have chronic
headaches so some of the time i not in the mood for doing anything.
anyway i will try to read up on stepper and figure em out i think i got a book somewhere about steppers
regards mike
