March 17, 2026, 11:34:58 11:34
Pages: 1 2 3 [4] 5
Author Topic: CCS, HI-TechC, MikroC , MPLAB C.....Which C Compiler is the BEST???  (Read 99259 times)
mabd
-Receive: 16
« Reply #75 on: February 15, 2008, 08:03:54 08:03 »
what about optimization and code genration?
I think MPLAB C is very good whatever mikroC more friendly
oinan
« Reply #76 on: February 17, 2008, 06:44:59 18:44 »
I used CC5X C and Hi-Tech C They're similar to ANSI C...
Posted on: February 17, 2008, 07:36:09 19:36 - Automerged
CCS C seems very useful has got many libraries but too different from ANSI C... and urges to memorize commands... but graph lcd libraries, ds memories, etc. makes its using necessary
JCC
« Reply #77 on: February 22, 2008, 11:35:43 23:35 »
MikroC because its easy to use and nice interface for beginner
fastlink30
-Given: 15
« Reply #78 on: February 23, 2008, 09:45:07 09:45 »
ccs for me, simple & quick to use
overmind
« Reply #79 on: May 05, 2008, 09:46:06 09:46 »
CCS C is really a great tool.. they also have have a wonderful forum site in www.ccsinfo.com/forum to help you if you encounter some problems..
manoon
« Reply #80 on: May 14, 2008, 02:32:59 14:32 »
Dear all,
Do you have the CD key for MPLAB C18 if have let me know.
Thank
mbandala
-Given: 130
-Receive: 305
« Reply #81 on: May 14, 2008, 03:48:46 15:48 »
Dear all,
Thank
CD key?
You don't need one, just check here...
http://www.sonsivri.com/forum/index.php?topic=2374.0
https://SecreLocal.com - One On One Chat - No Verify - Anonymous Adult Dating -   Secret Dating
ronbreukers
« Reply #82 on: May 14, 2008, 08:51:50 20:51 »
I am using CCS PCWHD 4.068 to program PIC24. However I lost already a lot of time to find and correct for bugs in the compiler. I could not get the RTC working, The interrupt failed etc. However for the PIC 18 and PIC 16 it works OK.
By the way I am looking urgently for an upgrade to this compiler...
I compared efficiency against assembly for a PIC 16F689 and programmed the same software in assembly and in C. The version in C was about 35% larger than the assembly language version. (4K in C against 3K in assembly)
I have no experience with other compilers, but my rule is for processors smaller than 4K, use assembly.
HTAluvBeBeo
« Reply #83 on: May 17, 2008, 04:38:10 04:38 »
Actually, a software written by CCS C cost more sapce of PIC than Compilers from Microchip. But CCS and Mikro C is more easy in than C18, C30.
Some experts advised me to learn C18, C30 for an efficient software.
I have the similar problem than ronbreukers with RTC  when using C languagle, but I can reslove it with MPLAB ASM.
In conclusion: In my opinion, CCS C and MikroC are both easy in use and very suitable for newbies or simply applications
MPLAP C would serve better but more difficult to use
juliano_cps
« Reply #84 on: May 18, 2008, 02:10:36 02:10 »
By the time that I have used CCS it have a lot of bugs... new releases every week... but, there are a lot of embeded functions, good for the starting users.
Now I use Hi-Tech PICC, it is a full ANSI C compiler... almost bug free... so it's my professional choice.
smainj
-Given: 70
-Receive: 75
« Reply #85 on: June 17, 2008, 10:30:07 22:30 »
the Best compiler is MPASM from microchip  Grin
mbandala
-Given: 130
-Receive: 305
« Reply #86 on: June 17, 2008, 11:27:48 23:27 »
Yes, MPASM is excellent, but is not a C or any other kind of compiler. MPASM stands for Microchip Assembler.
smainj
-Given: 70
-Receive: 75
« Reply #87 on: June 18, 2008, 02:21:13 14:21 »
when i need power im use  it with MikroC im write asm{ my code }
ta2lt
« Reply #88 on: June 18, 2008, 02:30:29 14:30 »
I use ccs but all complier usefull
elcielo
-Given: 115
« Reply #89 on: June 20, 2008, 03:45:33 15:45 »
compile code size ?
eeyrw
« Reply #90 on: July 23, 2008, 05:42:49 17:42 »
I like CCS.It's easy.
toml
« Reply #91 on: July 24, 2008, 03:40:48 03:40 »
When you consider which compiler is the best?
Maybe, you should ask whether that compiler can produce debug code for MPLAB,
so that you can debug programs inside MPLAB by using ICD or ReadIce. (affordable debuggers)
Secondly, check whether the compiler you choose provide enough libraries to ease the
common hardware problems.  MikroC is one of the best provides her own libraries to let
you to connect to RS232, CAN, MMC and ethernet etc.  You don't need to
search the useful libraries around, or write them from scratch.
No matter which compiler you choose, try hard and put some time to get familiar with that compiler,
then you may become one of the best engineer at the later time. Grin Grin Grin
sunskier
« Reply #92 on: August 06, 2008, 01:51:40 01:51 »
I am new too.
Because nobady could teach me, so I went to Microchip RTC to learn.
I use MPLAB C18 , but freeware is best...
etm503
« Reply #93 on: August 16, 2008, 02:22:29 14:22 »
I also think that the answer depends on which compliler one started on.
I started on CCS and it has proved more than adequate for my needs. I sometimes look at hi-tech and mikroc to learn a thing or two from their examples.
alpha
« Reply #94 on: August 16, 2008, 03:40:13 15:40 »
ccs,mikroc provides many built in libraries to control different types of peripherals
sunskier
« Reply #95 on: August 18, 2008, 07:02:53 07:02 »
i think all of them are good.
The most important thing is ...Do you have friends who knew PIC C language.
When u have problems u can ask them.
If u can't find anyone to ask, try to find some things at microchip website.
I also prefer C18 , because u can find source code, application notes, C user guide, a lot things at there.
My friend uses MikroC. He say MikroC has a lot of lib,easy to use...etc.
So, up to u.
bilalkaraaslan
« Reply #96 on: July 22, 2009, 09:28:08 09:28 »
you are new user so you can use CCS C or Mikro C. i think for profesional project you must use PICC18 or HI-Tech,IAR.
chyun3
-Given: 43
« Reply #97 on: August 09, 2009, 04:38:24 04:38 »
Hi guys,
I'm the one that started this thread, hihi.
My first PIC compiler is CCS, this is the compile that provide many "encapsulate" function (mean you only knew how to call that function, but you cannot modify/access to the function).
After that in my new company, i start to use the Hi-Tech compiler. Everything from the register setting to function have start writen from scratch.
Then i realized something, it maybe easier to startup using CCS, however it is quit dangerous since we don't know how the build-in function is written. When there is a fault, we will be in a confusion state asking is that built-in function that cause the bug & we unable to check this.
So basically what my advise is..., for the beginner, if time isn't the constraint, use Hitech or C18...it may take longer time to master it, but it is worth.
Above is just my opinion
arash_tah
« Reply #98 on: August 09, 2009, 05:10:14 05:10 »
MPLAB ir very original no bug and no limitation that's professional comppiler I strongly recomend you to use that
BharatSujanani
-Given: 36
-Receive: 24
All is Well
« Reply #99 on: August 10, 2009, 01:14:52 13:14 »
I have used MPLAB c18 and Hitech pro pic 16, but as my experience MPLAB C18 is stable and more optimizer.
HItech is more unstable from one to next patch level update are giving very big difference after size of compiled code.
Therefore observing all issues MPLAB compilers are better choice.
Bharat Sujanani
Pages: 1 2 3 [4] 5
