April 29, 2026, 12:30:32 12:30
Author Topic: [REQ] Current sensor  (Read 6824 times)
junaid_766
« on: January 09, 2010, 06:39:19 18:39 »
HI
i need a IC which measure current
Plz guide me
alien
-Given: 31
« Reply #1 on: January 09, 2010, 07:04:34 19:04 »
Dear Junaid,
Please visit below given link for excellent current sensing solutions >>
http://www.allegromicro.com/en/Products/Categories/Sensors/currentsensor.asp
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #2 on: January 10, 2010, 11:33:43 11:33 »
Hi, I used this one, very easy interface to analog port of any PIC or other micro. 5 V powered.
I do not remember the cost but I am shure it was not steep.
Greetings
Francisco
junaid_766
« Reply #3 on: January 10, 2010, 12:37:20 12:37 »
current which i want to measure its max value is 2A and is DC
sphinx
-Given: 683
-Receive: 393
« Reply #4 on: January 10, 2010, 12:46:01 12:46 »
if you want to measure dc current just use a low ohm resistor thats in series with with your gear and measure the voltage over the resistor with mcu or other komponents, its very simple
best regards
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #5 on: January 10, 2010, 05:07:43 17:07 »
Allegro has a cool IC for the job:
Fully Integrated, Hall Effect-Based Linear Current Sensor IC
with 3 kVRMS Voltage Isolation and a Low-Resistance Current Conductor
http://www.allegromicro.com/en/Products/Part_Numbers/0756/index.asp
borberk
-Given: 309
-Receive: 598
« Reply #6 on: January 11, 2010, 01:56:17 01:56 »
just as an idea
http://www.edn.com/article/CA6298271.html
http://www.edn.com/article/CA6418212.html
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #7 on: January 11, 2010, 02:44:42 14:44 »
best regards
Yes sir, I agree with sphinx.
Got this from futurlec, 0.1ohm 5W 5% Wirewound Resistor ( US$ 0.2 each )
For your 2 Amps the dissipated power ( heat ) would be in the range of 2*2x0.1 = 0.4 Watt and the Voltage drop 2x.01 = 0.2 Volt
Used these on output line of Battery chargers, no problem at all.
Greetings
Francisco
-Given: 405
-Receive: 545
« Reply #8 on: January 20, 2010, 02:57:09 14:57 »
Ran across this sensor
http://cgi.ebay.com/Honeywell-advanced-Hall-Open-loop-Current-Sensor_W0QQitemZ250566114873QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a56e77e39
titi
-Given: 4129
-Receive: 863
« Reply #9 on: January 20, 2010, 04:48:51 16:48 »
To Measure current from high-side there are some IC like :
  Zetex products: ZXCT1009, ZXCT1010, ZXCT1081 ...
  From Linear Technologie: LTC6101, LTC6101HV, LTC6103 ...
  From Maxim: MAX4172 ...
  Other: TSC101, SC310, FAN4010 ...
  APPLICATION NOTE 105 Current Sense Circuit Collection (See attachement)
Best Regards.
king
-Receive: 21
Jack of All But Master of One
« Reply #10 on: January 22, 2010, 09:56:02 09:56 »
use MAX472 IC which can measure current from 0 to 20A
Jehan
-Given: 51
« Reply #11 on: January 26, 2010, 10:24:16 22:24 »
For AC lowest cost is current transformer, for DC shunt, if isolation is needed Hall effect
