April 28, 2026, 01:25:44 01:25
Author Topic: ImageCraft.ICC.v7.22C.Pro.AVR  (Read 14203 times)
tomywong
-Given: 103
-Receive: 233
« on: January 08, 2010, 05:57:12 17:57 »
I haven't test it. Please try if you like it.
http://www.filefactory.com/file/a18ahg6/n/ICC722.rar
Pass : sonsivri.com
rentau
-Receive: 15
« Reply #1 on: March 04, 2010, 12:46:26 00:46 »
hi, KIS9 detected trojan on lavr.dll
everything has its beginning ,not all has its end~
lillbear
-Given: 223
-Receive: 182
« Reply #2 on: March 04, 2010, 11:02:20 11:02 »
F-Secure 9 -> worm.generic.xxxxxxx pla pla pla.
yours
sam_des
-Given: 138
-Receive: 161
« Reply #3 on: March 04, 2010, 05:39:14 17:39 »
Just a word of caution for those using this compiler. From v7.22, there is a bug with optimzations,
 -If you're using <=8k ROM devices such as m8 & enable both optimizations.
 -But compiler indicates that 'nothing worthwhile found' for optimization, then compiler incorrectly generates 'JMP' instead of 'RJMP' in final image for IVT & main().
 - Once your code is 'worthwhile' for optimzation, compiler now correctly generates 'RJMP'. So it is better to turn off optimizations during initial stages.
regards,
sam_des
« Reply #4 on: March 09, 2010, 09:06:01 09:06 »
Try this file, and report back if working ok or not.
rentau
-Receive: 15
« Reply #5 on: March 10, 2010, 01:36:06 01:36 »
after installation and change on lavr.dll first error.
Access violation at address 00351144 in module 'lavr.dll'. Read of address 00000FFF
and other error also.
« Reply #6 on: March 10, 2010, 06:42:22 06:42 »
try this one.
Edit: Strange.. More than 20 downloads, one reported that he has got a problem, what about others?
« Last Edit: March 10, 2010, 07:42:29 07:42 by metal » Logged
rentau
-Receive: 15
« Reply #7 on: March 10, 2010, 08:22:35 08:22 »
its still the same, same error. im using win sp3 btw
« Reply #8 on: March 10, 2010, 06:35:24 18:35 »
I only got SP2
« Last Edit: March 10, 2010, 08:55:31 20:55 by metal » Logged
rentau
-Receive: 15
« Reply #9 on: March 11, 2010, 12:17:27 00:17 »
anyone there could run some test on SP3?still not working.
simma
-Given: 24
« Reply #10 on: March 11, 2010, 01:57:16 01:57 »
Similar error on Xp SP3 too.
xp338
-Given: 249
-Receive: 47
« Reply #11 on: March 12, 2010, 05:03:37 17:03 »
This one work for me ( sp3)
I forgot where I got this. Credit to the Orginal post...
1. go to install dir /bin
2. Rename the lavr.dll to Orglavr.dll
3. Copy this "lavr.dll" to /bin
aamir
-Given: 37
-Receive: 229
« Reply #12 on: January 16, 2011, 07:47:33 07:47 »
Any one have new version 8
mitsos
-Given: 3308
-Receive: 5285
« Reply #13 on: January 16, 2011, 10:17:35 10:17 »
hi to all
after apply the patch,
I notice in the examples, when enable the optimization gives me bigger code than without optimization.
Is this problem of patch?
mitsos
