April 13, 2026, 11:50:02 11:50
Author Topic: 8051 Hex Code Explorer 1.0  (Read 6533 times)
94491203
-Given: 8
-Receive: 21
« on: December 10, 2009, 04:54:45 16:54 »
This program is written targeting INTEL's 8051 family 8 bit Microcontrollers (64KB of code memory). Limited to '16 bit address' data records. This program will parse and DisAssemble the hex code byte by byte data with addresses. It will show you the complete CODE memory map, the way your object code will reside in the code memory. It will help you to realize the exact picture about how your instruction set will stay physically in the code memory. View Details
http://www.spicelogic.com/Products/ShowDetails.aspx?productID=8051hexExplorer
« Last Edit: December 11, 2009, 11:03:33 11:03 by 94491203 » Logged
LEAS
-Receive: 19
« Reply #1 on: January 03, 2010, 08:17:11 08:17 »
after installation You must edit  8051hexExplorer.exe.config file to correctly way to files cinstruction_set.mdb uc8051labDB.mdb. Ithink that IDA is right select. Code explorer looks like a toy.
