April 20, 2026, 06:58:30 18:58
Author Topic: CONSTRUCAD 3D req  (Read 6893 times)
cncdude
-Given: 28
« on: December 09, 2009, 04:59:19 04:59 »
Hello im looking for this if anyone can help thanks for looking.
ps also if anyones used it what do you think of it?and are there other softwares that work the same way that you know of.
ive down loaded the demo to my pc but im unable to open it unless i call for a codethats,just to open the demo Cheesy
http://www.bk-faserverbundtechnik.at/cnc/index.php?option=com_content&view=article&id=33&Itemid=33
http://www.bk-faserverbundtechnik.at/cnc/images/stories/construcam/ConstruCAM_3D_DEMO_70208.rar
ConstruCAM-3D CNC-STEP is a program of einemHersteller with only a philosophy.  For the machining areas no program changes or changes in separate modules necessary also to send a cumbersome 'and' receive 'between the areas is unnecessary.
ConstruCAM-3D uses a single database, click on - just -All work will be permanently secured. Even if a power failure, no data is lost.
 ConstruCAM-3D is more than just a simple Gravierprogramm, it has the essential features of a professional milling software for the shallow and even for the 3D field, without thereby fleecing your wallet.
ConstruCAM 3D supported with numerous aids even the inexperienced user program: Already at the beginning of the start-up appears. The program includes a complete and up to date help on which may at any time with just one touch, even in previously activated function that can be accessed.  The menu record records all entries and information in your work and helps with unexpected effects.
Importfilter und Exportfilter Import and export filters, filter
 ConstruCAM-3D is not only interfaces to the most common standard formats, including EPS, HP-GL, DXF, or ISO, but also provides interfaces to essential imports such as engraving systems LONG, Kuhlmann, Baublys, Einzinger, isel, etc. This allows easy data are AutoCAD, CorelDRAW, Adobe Illustrator, and most CAD / CAM systems acquired and processed with the machine.
 ConstruCAM-3D, of course, has a complete CAD to generate toolpaths with construction tools, editing, Layer technology, tool management, etc. In addition to simply drawing with lines, arcs, splines and complex elements is added a complete design assistance. . With it, the target points can be entered quickly and accurately.  The extensive and sophisticated operations, like copy, mirror, rotate, distort, and many others are also available.
« Last Edit: December 09, 2009, 02:50:43 14:50 by daz » Logged
