April 21, 2026, 11:55:45 11:55
Author Topic: [REQ:] BARGRAPH CODE FOR 16x2 IN BASCOM  (Read 9657 times)
charudatt
-Given: 53
-Receive: 70
« on: November 06, 2009, 05:39:00 17:39 »
I am looking for a code snippet do display 8 DMX channel values on a 16x2 LCD (Second Line) using Bargraphs + AVR + BASCOM.
I searched the net but could not find any, there are codes for showing vu-meter but the bargraph is horizontal. I want them vertical.
Any help
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #1 on: December 13, 2009, 12:04:00 00:04 »
If you want them vertical you can use the same code. Just change the LCD routines
to "write-custom-chars" and then you can draw the values vertical.
You just need to calculate them a little bit because one char has 7*5 (8*5) dots.
If you have two lines (2 chars in one column = 1 bar):
The lower and the upper char of the first column are both 50% of the whole value (100% = 10 for example).
The lower char displays every value from 0%-49% and the upper one from 50%-100%.
I use this methode if I need to read all ADC channels for example.
Simple Calculation:
k = 10 = 100%
x = input (0-10+)
y=((100/k)*x) --> Input signal in %
1.0) if y <= 49 then clear the upper char
1.1) ROUND( y/7 ) --> amount of filled lines for the lower char
2.0) else if y > 49 then fill the lower char completely
2.1) ROUND( (y-50)/7 ) --> amount of filled lines for the upper char
optional:
3.0) else if y > 10 then fill lower+upper char or ERROR
4.0) else clear lower+upper char
Maybe I'll upload some pictures tomorrow if I have time to.
charudatt
-Given: 53
-Receive: 70
« Reply #2 on: December 13, 2009, 04:03:46 16:03 »
Looking forward to some examples with pictures, if you can, specially on how to "write-custom-chars"
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #3 on: December 14, 2009, 10:28:07 22:28 »
I had a little bit time today so I made a very simple example.
Here are pictures from the theory set up to practice:
http://img121.imageshack.us/img121/6674/lcd1.jpg
http://img706.imageshack.us/img706/1736/lcd2.jpg
http://img38.imageshack.us/img38/2751/lcd3w.jpg
http://img13.imageshack.us/img13/8853/lcd4.jpg
And there is a video from the test program I made (sorry for the blurred image -> cellphone camera):
http://www.youtube.com/watch?v=N2vefMl8DVM
And last but not least a tutorial on how to create custom chars for character LCD:
http://www.8051projects.net/lcd-interfacing/lcd-custom-character.php
Here is some code snippet from my very very simple calculation of the
vertical values as described in my previous post.
    y = 100;
    y /= k;
    y *= x;
    if(y<=50){
        y /= 8;
        lcd_gotoxy(0,1);
        lcd_putc(y);
    else if(y>50){
        y -= 50;
        y /= 8;
        lcd_gotoxy(0,1);
        lcd_putc(0x07);
        lcd_gotoxy(0,0);
        lcd_putc(y);
lcd_putc(0x07); means use the 8. custom char which is the full block alias the indicator for 50% (8*5 dots).
0x01 is just the line on the ground (1*5 dots) and 0x04 is half of a block = 25% (4*5 dots)
« Last Edit: December 14, 2009, 10:35:49 22:35 by DarkClover » Logged
