April 11, 2026, 11:00:43 23:00
Author Topic: timer problem in attiny13a  (Read 5531 times)
sphinx
-Given: 683
-Receive: 385
« on: October 25, 2009, 12:16:18 00:16 »
hi all
i am trying to learn som avr assembler and i succeded to learn some stuff like setting out puts and reading inputs
and some other simple stuff, but i am not able to get the TCNT0 in ATINY13A but i have been trying to figure it out
but i cant get the timer to start no matter of what i try i have been using avr simulator to see if it works but to no
luck.
i have attached some simple asm file just to get the hang of how the timer works, maybe someone can help with my
problem
best regards
sam_des
-Given: 138
-Receive: 161
« Reply #1 on: October 25, 2009, 01:49:20 13:49 »
Hello sphinx,
Try attached file. I've pointed out missing code & errors...
Hope that helps,
regads
sam_des
« Last Edit: October 25, 2009, 01:52:47 13:52 by sam_des » Logged
sphinx
-Given: 683
-Receive: 385
« Reply #2 on: October 25, 2009, 05:19:25 17:19 »
hi me again
i made some changes to the file and made it into a blinker at least it blinks slowly in proteus, i tried the same hex file in
AVR Simulator but there the same file wont work and thats a bit weird the tcnt0 wont change.
if someone else has simulator installed can try the file and give me a respoense back
your help was very much appreciated since my hair was getting more gray with this problem  Smiley
best regards
sam_des
-Given: 138
-Receive: 161
« Reply #3 on: October 25, 2009, 05:45:10 17:45 »
Well, it's working fine here. PORTB0 is getting toggled every 10mS @ 4MHz.
Did you single-stepped through delay10ms() ? Is delay10ms() never 'returning' ? It shouldn't if TCNT0 is not running.
And why don't you use 'sbi/cbi' instructions to toggle the PB0 ?
regards,
sam_des
sphinx
-Given: 683
-Receive: 385
« Reply #4 on: October 25, 2009, 06:03:43 18:03 »
ok thats good to know
it was some time ago i programmed in assembler and i was making it for z80 and that processor works a bit in a
different way, but i am trying to learn to programm avr and i gonna try to use sbi/cbi to set and clear ports
thanx for advice, i am happy for it
sphinx
tried it and it makes less code as well, so thats a good idea i will use Smiley
« Last Edit: October 25, 2009, 06:14:46 18:14 by sphinx » Logged
